[GRASS-dev] making py.monitor listen to external commands
Hallo,
I'm trying to script something, which could be in the future called
py.mon(itor) using wxpython together with xrc.
The basic is here - I can display ppm file
Now, I would like to make it "listen" to command line commands and I
have been thinking of approach like this:
The idea is, you would tip just normal py.* commands in the command line,
but there would be process running in background, which would pick up
the last line from history file (e.g. .monitor_x0_history) and add it to stack of
commands for the monitor.
We would have to create set of py.* commands, which would replace the
d.* commands and general structure of this py.* commands would look like
this:
# py.rast
# get the selected monitor
monitor = os.getenv("GRASS_MONITOR")
# get the file name
command_file = os.path.join(GISBASE,LOCATION,MAPSET,".monitor_"+monitor+"_history)
# write d.rast to commands
file = open(command_file,"a")
file.write("d.rast "+sys.arg[1:])
file.close()
Then there should be loop in py.monitor:
    1) watcher(), which would take care on the .monitor_x0_history file just like tail -f does
       if there would be some change, it would add command to the
        monitor commands stack and redraw the monitor with new set of
        commands
    2) pymonitor.MainLoop(), which displays the gui and sets the
        variables
So, I have monitor (see screenshot [1]), I can tip commands in some
"terminal" under the window. I have "watcher" which takes care on the
command file and if there is some change, it should set the "monitor
terminal" to the value of the command(s) to new command.
But it does not because the processes do not "see" each other. I'm also
not able to kill the processes while closing the monitor, because of I'm
not able to get their PIDs.
So my question: how to perform task like this? I know, this is task for
"reall" programmers, maybe I choosed completly wrong approach.
I took the code from
http://aspn.activestate.com/ASPN/Cookbook/Python/Recipe/66012 and
modified it like this:
class Monitor(wx.App):
    py.monitor gui
    def OnInit(self):
        Init the gui
        try:
            pid = os.fork()
            if pid > 0:
                # exit first parent
                sys.exit(0)
        except OSError, e:
            print >>sys.stderr, "fork #1 failed: %d (%s)" % (e.errno,
    e.strerror)
            sys.exit(1)
        # decouple from parent environment
        os.setsid()
        os.umask(0)
        # initialize the GUI
        self.initFrame()
        self.rast = map.raster.Raster()
        self.initToolBar()
        self.initCommands()
        self.initDrawArea()
        self.frame.Show()
        # do second fork
        try:
            pid = os.fork()
            if pid > 0:
                # exit from second parent, print eventual PID before
                #print "Daemon PID %d" % pid
                # OnInit should return boolean value
                return True
                #sys.exit(0)
        except OSError, e:
            print >>sys.stderr, "fork #2 failed: %d (%s)" % (e.errno,
    e.strerror)
            sys.exit(1)
        # start the daemon watcher
        self.watcher()
# startin the gui
def main():
    pymonitor = Monitor(0)
Thanks for hints I hope, one can understand, what I wanted to say.
Jachym
[1] http://les-ejk.cz/tmp/py.monitor.png
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky@gdf-hannover.de
URL: http://gdf-hannover.de
Tel.: +49 511-39088507
One thing that might be helpful is to have a file which lists the
currently displayed ppm images (in the monitor) in the order that they
are displayed. Then a command line program could replace the list with
new data (d.erase) or append to the list (d.rast -o). The monitor
would need to check if the list had been changed and then update
itself (maybe after receiving an update yourself signal via a socket)
Ideally, the monitor list would contain enough information to update
the gis.m widgets as well.
In other words, d.erase would erase the monitor and (optionally) also
remove all the drawing "widgets" from gis.m. Issuing a d.rast command
would, in addition to updating the monitor, replace or append to the
gis.m widgets as appropriate.
David Finlayson
yes, yes, that is no question about what it should do
def watcher(self):
    commands_file = "py.commands"
    commands = open(commands_file,"r")
    st_results = os.stat(commands_file)
    st_size = st_results[6]
    commands.seek(st_size)
    while 1:
        where = commands.tell()
        line = commands.readline()
        if not line:
            time.sleep(1)
            commands.seek(where)
        else:
            line = line.strip()
            if line == "d.erase":
                self.commandsCtrl.SetValue('')
            else:
                    self.commandsCtrl.GetValue()+"\n"+line+"\n")
But how?
I have rewritten the code a bit, but it does not seem, that both
processes would have same space in memory :frowning:
    def OnInit(self):
        try:
            pid = os.fork()
            if pid == 0:
                self.watcher()
            else:
                print self.semafor
                print "otec"
        except OSError, e:
            # no fork
            sys.exit(1)
        return True
It would be maybe better, do it in MainLoop, but I did not found the
approach, how to smuggle watcher() in the MainLoop :frowning:
Jachym
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
It's worthwhile to see how we've done this same kind of thing in the GIS
Manager console using TclTk.
If the commands are done through the GUI or a python command console, it
really isn't necessary to constantly listen for commands because the user is
the one who issues commands. These commands can be captured at the time they
are issued by the user and echoed back to the command history console. The
stdout and stderr from each command can also be captured and echoed back.
Since all this is simply text (commands and their output), it can go into a
scrolling text widget producing a history of commands and output.
In other words, this can be be event driven in a simple, straightforward
manner. Pressing "run" button (if default, pressing return) runs a command
and echoes the command to history. When a command is issued, its output is
automatically captured and sent to history.
This done in a more sophisticated way in the gronsole that Cedric Shock did.
It separates commands from their output and allows the output to be folded
out of sight. Buttons that are put into the text widget alongside each
command will automatically copy the command from history back to the command
console where it can be edited and run again.
Hope this helps
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Mon, 12 Jun 2006 21:47:22 +0200
To: David Finlayson <david.p.finlayson@gmail.com>
Cc: <grass-dev@grass.itc.it>
Subject: Re: [GRASS-dev] making py.monitor listen to external commands
def watcher(self):
    while 1:
        if not line:
            time.sleep(1)
        else:
            line = line.strip()
            else:
But how?
    def OnInit(self):
        try:
            pid = os.fork()
            if pid == 0:
                self.watcher()
            else:
                print self.semafor
                print "otec"
        except OSError, e:
            # no fork
            sys.exit(1)
        return True
Jachym
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
are displayed.
does d.save help?
Hamish
D.save only works with commands sent to the XDRIVER. It would be much more
useful if it kept track of all GRASS commands and didn't depend on x11.
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Tue, 13 Jun 2006 17:54:15 +1200
Cc: <jachym.cepicky@centrum.cz>, <grass-dev@grass.itc.it>
are displayed.
does d.save help?
Hamish
Hallo,
after long discussion with Michael and a bit coding, I would like to
present new new concept of GRASS monitors.
I prepared set of py.* commands, which IMHO *should* became parts of d.*
commands. This is just a workaround this.
General concept is, each monitor has it's own LOCATION/MAPSET/.pyX file,
in which the d.* files are stored. This file is checked from the GUI and
if there is some change, it's content serves for creating the map.
Advantage of this approach is, that this file can be modified from any
GUI/CLI. Target is, to have py.mons *independent* on any UI, however
managable from *any* of them.
Screenshot can be found on [1], set of new tools can be found on [2].
Example session (in xterm) can look like follows:
py.mon start=x0
py.mon start=py0
py.rast soils
py.vect roads
py.ctrl -l
py.ctrl remove=vect
py.rast fields -o
py.vect fields fcol=yellow
py.ctrl -l
(see screenshot [1] for details and possible outputs).
py.rast and py.vect commands can be used just like the old d.* commands
for installation just untar [2] and cd new py.monitor directory
[1] http://les-ejk.cz/tmp/py.mon.png
[2] http://les-ejk.cz/programs/grass/py.monitor.tgz
Please test and discusse.
Jachym
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
Hallo,
bugfix version of py.monitor scripts. Some people tested the scripts and
they found it nice. What about you, developers?
Current version avaliable on
http://les-ejk.cz/programs/grass/py.monitor-06-06-14-4.tgz
tar xzf py.monitor-06-06-14-4.tgz
cd py.monitor
py.mon start=py0
py.rast soils -o
py.vect roads
py.erase
Everything, what should work (all toolbar buttons, etc.) works. Zoom/Unzoom
avaliable via mouse wheel. Mapcontent manageable via py.* commands (this
should move to d.* commands in the future) from commandline and via any
other interface via LOCATION/MAPSET/.pyX file.
Starting with the morning, I will not have much time and I will not be
so close to internet for a week, so I will not spam your mailboxes
for a while.
It would be good just to send me some note, e.g., that you tryed, but it did
not work. It is not so easy to develop GUI without any feedback.
Looking forward
Jachym
On Wed, Jun 14, 2006 at 11:34:09AM +0200, Jachym Cepicky wrote:
Hallo,
py.mon start=x0
py.mon start=py0
py.rast soils
py.vect roads
py.ctrl -l
py.ctrl remove=vect
py.rast fields -o
py.ctrl -l
Jachym
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
grass-dev mailing list
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
OK, I don't know much about Python, but this is what I get
when I do: ./py.mon start=py0
   File "mon.py", line 15, in ?
     import wx
   File "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-ansi/wx/__init__.py", line 42, in ?
     from wx._core import *
   File "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-ansi/wx/_core.py", line 4, in ?
     import _core_
ImportError: /usr/lib/python2.4/site-packages/wx-2.6-gtk2-ansi/wx/_core_.so: symbol _ZTV17wxMemoryFSHandler, version WX_2.6 not defined in file libwx_gtk2_core-2.6.so.0 with link time reference
... so one more dependency to worry about in the future?
Or is this something that can easily be taken care of with a
modified configure script?
Best,
Benjamin
Hallo,
cd py.monitor
py.mon start=py0
py.rast soils -o
py.vect roads
py.erase
for a while.
Looking forward
Jachym
Hallo,
py.mon start=x0
py.mon start=py0
py.rast soils
py.vect roads
py.ctrl -l
py.ctrl remove=vect
py.rast fields -o
py.vect fields fcol=yellow py.ctrl -l
Jachym
Jachym Cepicky
----------------------------------------- OFFICE: GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
OK, I installed wxpython on my Gentoo Linux box.
This is what I get now:
/usr/lib/python2.4/site-packages/wx-2.6-gtk2-ansi/wx/_core.py:13155: UserWarning: wxPython/wxWidgets release number mismatch
   warnings.warn("wxPython/wxWidgets release number mismatch")
   File "mon.py", line 314, in ?
     main()
   File "mon.py", line 293, in main
   File "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-ansi/wx/_core.py", line 7473, in __init__
     self._BootstrapApp()
   File "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-ansi/wx/_core.py", line 7125, in _BootstrapApp
     return _core_.PyApp__BootstrapApp(*args, **kwargs)
   File "mon.py", line 54, in OnInit
     self.initDrawArea()
   File "mon.py", line 101, in initDrawArea
     self.back.getRegion()
   File "/home/benni/grass-cvs/py.monitor-06-06-14-4/map/raster.py", line 138, in getRegion
     key,value = line.split(":")
ValueError: too many values to unpack
Obviously due to a minor difference in library versions.
But I don't understand the message well enough to know what exactly
the problem is.
Benjamin
  Jáchym Èepický wrote:
Hallo,
yes, most of the developers desided, that wxwindows and python are the best tools which are working on *every* supported platform. I personaly would choose pygtk. But as long as you have wxwidgest and python in your system, this should work. This should also work, if you try it on ms windows - you should not need xdriver at least for the basic operation.
anyway, if you want to get rid of xdriver, you need somethign else - some other dependency.
look after thy wxpython package, it should help
jachym
______________________________________________________________
Od: benjamin.ducke@ufg.uni-kiel.de
Komu: grass-dev@grass.itc.it
Datum: 15.06.2006 10:17
Pøedmìt: Re: [GRASS-dev] making py.monitor listen to external commands
   import wx
File
42, in ?
line 4, in ?
   import _core_
ImportError:
Best,
Benjamin
Hallo,
and
cd py.monitor
py.mon start=py0
py.rast soils -o
py.vect roads
py.erase
Zoom/Unzoom
(this
be
for a while. > > It would be good just to send me some note, e.g., that
Looking forward > > Jachym
Hallo,
d.*
file,
and
py.mon start=x0
py.mon start=py0
py.rast soils
py.vect roads
py.ctrl -l
py.ctrl remove=vect
py.rast fields -o
py.vect fields fcol=yellow >>py.ctrl -l
Jachym
-- >>Jachym Cepicky
GPG:
----------------------------------------- >>OFFICE:
                  >>GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
-- Benjamin Ducke, M.A.
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
What are the release numbers of the two, i.e. of wxPython and of wxWidgets (called libwxgtk in Debian) ?
Moritz
It seems that wxwidgets is 2.6.2 while
wxpython is 2.6.1. Could that be enough to cause
trouble?
Benjamin
Moritz
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
trouble?
Can you put them to equal versions and see ?
Moritz
Benjamin
Moritz
Hallo,
I just tryed the py.mon stuff on win xp box and it nearly worked :slight_smile: the window appears, but I did not manage to display any map.
this just means, that used approach (python + wxwidget) seem really to work on windows and that it can use at least some commands from grass via os.system()
screenshot on les-ejk.cz/tmp/pymon-win.png [0.5 MB]
Have a nice weekend
Jachym
P.S. I used Wingrass (qgis+grass) precompiled package from Radim, started qgis, started GRASS-Shell and run. Maybe in commandline.exe it would work better?
Jachym Cepicky
OFFICE:
Department of Geoinformation Technologies
LDF MZLU v Brnì
Zemìdìlská 3
613 00 Brno
e-mail: xcepicky@node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
Od: jachym.cepicky@centrum.cz
Datum: 12.06.2006 20:32
Pøedmìt: [GRASS-dev] making py.monitor listen to external commands
Hallo,
stack of
this:
# py.rast
# get the file name
command_file =
file.close()
       commands
       variables
   py.monitor gui
   def OnInit(self):
       Init the gui
       try:
           pid = os.fork()
           if pid > 0:
               # exit first parent
               sys.exit(0)
       except OSError, e:
   e.strerror)
           sys.exit(1)
       os.setsid()
       os.umask(0)
       self.initFrame()
       self.initToolBar()
       self.initCommands()
       self.initDrawArea()
       self.frame.Show()
       # do second fork
       try:
           pid = os.fork()
           if pid > 0:
               return True
               #sys.exit(0)
       except OSError, e:
   e.strerror)
           sys.exit(1)
       self.watcher()
# startin the gui
def main():
Jachym
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
I just updated wxpython to the newest version, compiled from
source and this is the result:
     import wx
     import _core_
ImportError: /usr/lib/libwx_base_odbc-2.6.so.0: symbol _ZN9wxVariantaSEPK14tagDATE_STRUCT, version WX_2.6 no t defined in file libwx_base-2.6.so.0 with link time reference
Forgive me, but I am starting to like Tcl/Tk more and more.
That has worked for me without a flaw since 1996 ...
Benjamin
Hallo,
Have a nice weekend
Jachym
Jachym Cepicky e-mail: jachym.cepicky@centrum.cz URL: http://les-ejk.cz GPG: http://les-ejk.cz/gnupg\_public\_key/ ----------------------------------------- OFFICE: Department of Geoinformation Technologies LDF MZLU v Brnì Zemìdìlská 3 613 00 Brno e-mail: xcepicky@node.mendelu.cz URL: http://mapserver.mendelu.cz
Hallo,
stack of
this:
# py.rast
# get the file name
command_file =
file.close()
      commands
      variables
  py.monitor gui
  def OnInit(self):
      Init the gui
      try: pid = os.fork() if pid > 0:
              # exit first parent
              sys.exit(0) except OSError, e: print >>sys.stderr, "fork #1 failed: %d (%s)" % (e.errno,
  e.strerror) sys.exit(1)
      os.setsid() os.umask(0)
      self.initFrame()
      self.initToolBar()
      self.initCommands()
      self.initDrawArea()
      self.frame.Show()
      # do second fork
              return True
              #sys.exit(0) except OSError, e: print >>sys.stderr, "fork #2 failed: %d (%s)" % (e.errno,
      self.watcher()
# startin the gui
def main():
Jachym
Jachym Cepicky
Mengendamm 16d
30177 Hannover
Germany
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
Right, I fixed linker symbol problem by compiling wxpython
with exactly the same options as wxwidgets (both newest
versions).
Now I am back to the old error:
     main()
     self.initDrawArea()
No idea what to do about this.
Btw.: if py.mon crashes before it even gets a chance to open a
monitor, it still leaves a lockfile .py0 in the current mapset
preventing it to start next time.
Best,
Benjamin
Hallo,
Have a nice weekend
Jachym
Hallo,
stack of
this:
# py.rast
# get the file name
command_file =
file.close()
      commands
      variables
  py.monitor gui
  def OnInit(self):
      Init the gui
              # exit first parent
      self.initFrame()
      self.initToolBar()
      self.initCommands()
      self.initDrawArea()
      self.frame.Show()
      # do second fork
              return True
      self.watcher()
# startin the gui
def main():
Jachym
Jachym Cepicky
Mengendamm 16d
30177 Hannover
Germany
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
