[GRASS-dev] making r.out.gdal region sensitive
hi,
according to
http://grass.gdf-hannover.de/wiki/GRASS_6.2_Feature_Plan#RC3.2FFinal
i prepared 2 lines patch for this. it works for me, should i apply?
jachym
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
Department of Geoinformation Technologies
Zemedelska 3
613 00, Brno
Czech Republick
e-mail: xcepicky@node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
(attachments)
r.out.gdal.patch (708 Bytes)
I think r.out.gdal should be region sensitive, the patch looks like OK for me...
Best, Martin
2006/10/17, Jachym Cepicky <jachym.cepicky@centrum.cz>:
hi,
according to
jachym
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2.2 (GNU/Linux)
iD8DBQFFNUH4yKt0uAjU4I8RAkgDAJ9e1vU5W1YquohFZ0Z0AB8XveUmngCfU72r
yvxifRiQzZKnCyuQUNVMwGc=
=AVA3
-----END PGP SIGNATURE-----
grass-dev mailing list
grass-dev@grass.itc.it
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
Hello Jachym
In order for the behaviour of r.out.gdal to be consistent with other r.out.* modules, I think it would be more appropriate for it to first use r.resample to resample the map according to the current region (this is what the other modules do) into a temporary raster map and then export that.
Paul
On Tue, 17 Oct 2006, Jachym Cepicky wrote:
hi,
according to
jachym
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
according to
Please, but only as an option. We can't remove any current behavior
unless it's a bug.
In GRASS 7 region-sensitiveness in r.out.gdal should become the default
however - for consistency with other r.out.* modules.
Maciek
hallo,
On Tue, Oct 17, 2006 at 10:56:58PM +0100, Paul Kelly wrote:
Hello Jachym
use
is
that.
could you point me to some example? how to create temporary raster file?
i tryed something, see this patch
unless it's a bug.
default
i added -r flag for "region sensitive"
jachym
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
(attachments)
r.out.gdal.patch (1.55 KB)
Hello Jachym,
That looks OK, but I made some (untested) changes to your patch (see attached). First of all the re-sampled map will automatically cover the current region only so you do not need the extra -projwin bit on the gdal command line. Also I didn't understand what the '' was in the temporary filename: temporary_$INPUT''_$$ - why not r.out.gdal_${INPUT}_$$ ? I put r.out.gdal in the name so it is more obvious where it came from if for some reason it doesn't get deleted (e.g. the script is interrupted). Also changed the g.remove bit to remove the temporary filename variable. This won't be set if the -r flag isn't used so there's no chance of the real input map being accidentally deleted in some unlikely circumstances. In fact you don't really need the test for the -r flag at the end - you could just forcibly remove that file and if it didn't exist (i.e. -r flag wasn't used) it would be OK. But having the check for the flag in makes it tidier I think.
What do you think?
Paul
On Wed, 18 Oct 2006, Jachym Cepicky wrote:
hallo,
Hello Jachym
use
is
that.
unless it's a bug.
default
jachym
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
(attachments)
Oops, the line endings on that patch got corrupted - please look at this one instead.
hallo,
Hello Jachym
use
is
that.
unless it's a bug.
default
jachym
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
(attachments)
r.out.gdal.patch (1.49 KB)
hi
On Wed, Oct 18, 2006 at 09:56:22AM +0100, Paul Kelly wrote:
What do you think?
Paul
i think, that you are much better coder :slight_smile:
thanks for the hints, i'll have a look at this
jachym
>hallo,
>>Hello Jachym
>>use
>>is
>>that.
>>unless it's a bug.
>>default
>jachym
>Jachym Cepicky
>OFFICE:
>Zemedelska 3
>613 00, Brno
>Czech Republick
Index: r.out.gdal
RCS file: /grassrepository/grass6/scripts/r.out.gdal/r.out.gdal,v
retrieving revision 1.24
diff -u -r1.24 r.out.gdal
--- r.out.gdal 19 Aug 2006 12:52:24 -0000 1.24
+++ r.out.gdal 18 Oct 2006 08:07:59 -0000
@@ -22,6 +22,10 @@
#% key: l
#% description: list supported output formats
#%END
+#%flag
+#% key: r
+#% description: region sensitive output
+#%END
#%option
#% key: input
#% type: string
@@ -89,6 +93,7 @@
OUTPUT="$GIS_OPT_OUTPUT"
CREATEKEY="`echo "$GIS_OPT_CREATEOPT" | sed 's+,+ -co +g' | sed 's+^+-co +g'`"
METAKEY="`echo "$GIS_OPT_METAOPT" | sed 's+,+ -mo +g' | sed 's+^+-mo +g'`"
+REGION=""
if [ $GIS_FLAG_L -eq 1 ] ; then
   gdal_translate | grep ':' | grep -v 'Usage' | grep -v 'The following'
@@ -99,6 +104,15 @@
#echo $INPUT $FORMAT $OUTPUT
#echo $GDAL_INPUT_FORMATS
+# region sensitive output
+if [ $GIS_FLAG_R -eq 1 ] ; then
+ TEMPRASTER=r.out.gdal_${INPUT}_$$
+ r.resample input=$INPUT output=$TEMPRASTER
+ INPUT=$TEMPRASTER
+fi
#fetch the input raster map
eval `g.findfile element=cell file=$INPUT`
if [ ! "$file" ] ; then
@@ -129,9 +143,14 @@
   unset METAKEY
fi
#do it
CELLHD=`echo $file | sed 's+/cell/+/cellhd/+g'`
echo "Writing format: $FORMAT"
echo "Writing type: $TYPE"
gdal_translate -of $FORMAT -ot $TYPE $CREATEKEY $METAKEY $CELLHD $OUTPUT
+ g.remove $TEMPRASTER
+fi
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
hi,
i tested the patch and it works ok (also on lat/long location). since nobody complained against this new feature, i committed
the patch to cvs
many thanks to Paul, the author of this patch
jachym
one instead.
>hallo,
>>Hello Jachym
>>use
>>is
>>that.
>>unless it's a bug.
>>default
>jachym
>Jachym Cepicky
>OFFICE:
>Zemedelska 3
>613 00, Brno
>Czech Republick
Index: r.out.gdal
@@ -22,6 +22,10 @@
#% key: l
#%END
+#%flag
+#% key: r
+#%END
#%option
#% key: input
#% type: string
@@ -89,6 +93,7 @@
+REGION=""
@@ -99,6 +104,15 @@
+ INPUT=$TEMPRASTER
+fi
   unset METAKEY
fi
#do it
+fi
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
+ INPUT=$TEMPRASTER
Possible addition:
+else
+ echo "WARNING: future versions will use current region by default" >&2
just a check re. region bounds & grid vs. pixel conventions, does a
full cycle result in the same exact data?
r.out.gdal -r in=orig_map format=[...] out=map.ext
r.in.gdal in=map.ext out=map2
r.resample in=orig_map out=orig_map.resamp
r.mapcalc diff="orig_map.resamp - map2"
r.univar diff
Hamish
hi,
r.univar diff
Hamish
if i understand this well, you are asking for result like this:
d.zoom
r.out.gdal -r in=soils type=Byte out=map.ext
r.in.gdal in=map.ext out=map2 --o
r.resample in=soils out=soils.resamp --o
r.mapcalc diff="soils.resamp - map2"
r.univar diff
total null and non-null cells: 29382
total null cells: 0
Of the non-null cells:
n: 29382
minimum: 0
maximum: 0
range: 0
mean: 0
mean of absolute values: 0
standard deviation: 0
variance: 0
variation coefficient: nan %
sum: 0
i would say, this looks good(?)
jachym
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
d.zoom
yes
r.univar diff
total null cells: 0
n: 29382
minimum: 0
maximum: 0
range: 0
mean: 0
variance: 0
sum: 0
I would say this looks very good! Thanks.
Hamish
