[wish]
Could man/Makefile
be rewritten to include/Make/Man.make
This would help to obtain a (almost) functional "make install" target.
My Makefile skills are unfortunately too limited...
[wish]
Could man/Makefile
On Sat, Apr 11, 2009 at 9:11 PM, Markus Neteler <neteler@osgeo.org> wrote:
[wish]
Could man/Makefile
OK, have submitted that including
make install
target to 6.4.0svn and 6.5svn. No idea how to do it for 7.
Markus Neteler wrote:
Could man/Makefile
What would be the point? The point of including *.make files is that
you can have a common set of rules which are included in multiple
Makefiles. Given that only man/Makefile would be using those rules,
they may as well go into man/Makefile directly.
On Sun, Apr 12, 2009 at 3:29 PM, Glynn Clements
Could man/Makefile
?What would be the point? The point of including *.make files is that
The point is that for a "make install" target (main, addons) the MAN
page needs to be generated immediately like the HTML file, not in
a global loop.
>> Could man/Makefile
> they may as well go into man/Makefile directly.The point is that for a "make install" target (main, addons) the MAN
a global loop.
That's already the case in 7.0. man/Makefile will typically only build
the manpages for the indices; all of the module manpages should
already have been built by that point.
[The original reason for the change was so that any error in
generating the manpage would occur while making the module in
question.]
I'm not contesting the desirability of an "install" target, just the
need for a Man.make file (7.0 has the rules in Html.make, as this is
already included by anything which has HTML documentation from which
the manpage could be built).
