[GRASS-dev] Map_info with_z
currently dimension of vector map is stored in three different places (vlib)
Map->plus.spidx_with_z (Plus_head) -> spatial index
Map->plus.with_z (Plus_head) -> topology
Map->head.with_z (Map_info) -> head
Is it really needed?
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
similar for `mode`
  Map->mode = GV_MODE_READ;
  Map->plus.mode = GV_MODE_READ;
2012/1/21 Martin Landa <landa.martin@gmail.com>:
Martin
Martin Landa wrote:
That is coming from GRASS 5 and used as a safety check that the
spatial index has the same dimensions like the coordinates. It can
probably be removed.
Needed by diglib, because diglib functions get only Map->plus, not Map itself.
Needed for reading and writing coordinates and if no topology is
available or requested (e.g. v.info, v.surf.*).
Markus M
Martin:
Markus Metz:
It can probably be removed.
please don't remove safety checks [if they are still meaningful].
they are there for a (very good) reason.
thanks,
Hamish
