Since it's somewhat cumbersome to work with multiple `MASK's
currently (`r.reclass', `g.copy'?), I'd like to introduce
`MASK_OVERRIDE' -- an environment variable analogous to
`WIND_OVERRIDE'.
lib/gis/auto_mask.c (G__check_for_auto_masking): Handle `MASK_OVERRIDE';
allow mask to be in any mapset in the search path.
lib/gis/mask_info.c (G__mask_info): Likewise.
diff --git a/lib/gis/auto_mask.c b/lib/gis/auto_mask.c
index 6828018..0dc218d 100644
--- a/lib/gis/auto_mask.c
+++ b/lib/gis/auto_mask.c
@@ -32,6 +32,7 @@
int G__check_for_auto_masking (void)
+ char name[GNAME_MAX] = "MASK", mapset[GMAPSET_MAX] = "";
struct Cell_head cellhd;
/* if mask is switched off (-2) return -2
@@ -42,14 +43,26 @@ int G__check_for_auto_masking (void)
/* if(G__.mask_fd > 0) G_free (G__.mask_buf);*/
- /* look for the existence of the MASK file */
- G__.auto_mask = (G_find_cell ("MASK", G_mapset()) != 0);
+ /* check for MASK_OVERRIDE */
+ const char *override = getenv ("MASK_OVERRIDE");
+ if (override != 0) strncpy (name, override, sizeof (name));
+ /* look for the existence of the MASK file; get the mapset name */
+ char *mask_mapset = G_find_cell (name, mapset);
+ if ((G__.auto_mask = (mask_mapset != 0)) > 0) {
+ strncpy (mapset, mask_mapset, sizeof (mapset));
if (G__.auto_mask <= 0)
return 0;
/* check MASK projection/zone against current region */
- if (G_get_cellhd ("MASK", G_mapset(), &cellhd) >= 0)
+ if (G_get_cellhd (name, mapset, &cellhd) >= 0)
if (cellhd.zone != G_zone() || cellhd.proj != G_projection())
@@ -59,11 +72,12 @@ int G__check_for_auto_masking (void)
G_unopen_cell(G__.mask_fd );
- G__.mask_fd = G__open_cell_old ("MASK", G_mapset());
+ G__.mask_fd = G__open_cell_old (name, mapset);
if (G__.mask_fd < 0)
G__.auto_mask = 0;
- G_warning (_("Unable to open automatic MASK file"));
+ G_warning (_("Unable to open automatic MASK (<%s@%s>) file"),
+ name, mapset);
return 0;
diff --git a/lib/gis/mask_info.c b/lib/gis/mask_info.c
index b82e8ea..dd7f905 100644
--- a/lib/gis/mask_info.c
+++ b/lib/gis/mask_info.c
@@ -58,11 +58,32 @@ int G__mask_info (
char rname[GNAME_MAX], rmapset[GMAPSET_MAX];
- strcpy (name, "MASK");
- strcpy (mapset, G_mapset());
+ /* NB: the following is painfully close to G__check_for_auto_masking
+ * (); consider a separate function here
- if(!G_find_cell (name, mapset))
- return -1;
+ if (override != 0) {
+ strncpy (name, override, sizeof (name));
+ } else {
+ strcpy (name, "MASK");
+ char *mask_mapset = G_find_cell (name, "");
+ if (mask_mapset == 0) {
+ /* NB: `mapset' won't be initialized */
+ return -1;
if(G_is_reclass (name, mapset, rname, rmapset) > 0)
