On Feb 5, 2008, at 8:20 AM, grass-dev-request@lists.osgeo.org wrote:
Date: Tue, 5 Feb 2008 10:20:02 -0500
Subject: [GRASS-dev] MASK seems to be ignored
To: <grass-user@lists.osgeo.org>
Cc: grass-dev@lists.osgeo.org
Message-ID:
<CA803441152AAE40935609509953BAD201075FB6@s0-ott-x4.nrn.nrcan.gc.ca>
Content-Type: text/plain; charset="iso-8859-1"Hi,
I'm having problems getting a MASK to actually mask anything.
$ r.mask in=Diff_Nov2007_Oct2007_1m
MASK created. All subsequent raster operations
will be limited to MASK area
Removing or renaming raster file named MASK will
restore raster operations to normal
[Raster MASK present]Yet all refreshes of the gis.m map display window do not clip the display extents
based on the new mask(see attached png). In the screenshot, the mask is the pink raster,
and underneath it is another raster in my mapset. Shouldn't the underlying raster's display
be clipped to that of the mask?Using r.mapcalc while the mask exists also doesn't seem to obey the extents of the mask, i.e.:
r.mapcalc test = 'Diff_Oct2007_Mar2007_1m'
This creates the raster 'test' with data extents that match Diff_Oct2007_Mar2007_1m, not the mask's
boundaries.I'm using svn-trunk compiled from today's source.
~ Eric.
Eric,
The way I understand it is that a MASK will affect all subsequent *read* operations for processing a raster map. That is...
r.mapcalc 'newmap=oldmap'
...will just produce an unaltered copy of oldmap without a MASK; with a MASK it will produce a copy of oldmap only in the area of MASK.
MASK will not affect the display. It is for map processing.
Michael
