Just out of curiosity, why is there an upper limit to the memory we can use on operations like r.in.gdal?
with kind regards,
Panos
with kind regards,
Panos
On Mon, Jan 11, 2016 at 8:04 PM, Panagiotis Mavrogiorgos
<pmav99@gmail.com> wrote:
The question is too generic, so I'll refer to r.in.gdal only:
To my knowledge there is a GDAL imposed CACHE limit
https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.in.gdal/main.c#L271
271 /* default GDAL memory cache size appears to be only 40 MiB,
slowing down r.in.gdal */
272 if (parm.memory->answer && *parm.memory->answer) {
273 /* TODO: GDALGetCacheMax() overflows at 2GiB, implement
use of GDALSetCacheMax64() */
274 GDALSetCacheMax(atol(parm.memory->answer) * 1024 * 1024);
but concerning the data you can import I am not aware of any limit.
Maybe this page is of interest to you:
https://grasswiki.osgeo.org/wiki/Large_raster_data_processing
What is exactly your problem you encountered?
> Hi all,
use
> on operations like r.in.gdal?The question is too generic, so I'll refer to r.in.gdal only:
To my knowledge there is a GDAL imposed CACHE limithttps://trac.osgeo.org/grass/browser/grass/trunk/raster/r.in.gdal/main.c#L271
274 GDALSetCacheMax(atol(parm.memory->answer) * 1024 * 1024);but concerning the data you can import I am not aware of any limit.
https://grasswiki.osgeo.org/wiki/Large_raster_data_processingWhat is exactly your problem you encountered?
Thank you Marcus,
That was really helpful. I don't have a particular problem. I just found
strange that the limit was so low on x64 architectures.
with kind regards,
Panos
On Jan 13, 2016 9:28 AM, “Panagiotis Mavrogiorgos” <pmav99@gmail.com> wrote:
That was really helpful. I don’t have a particular problem. I just found strange that the limit was so low on x64 architectures.
Which limit do you refer to?
Best
