When running pygrass.utils.get_raster_for_points repeatedly, it appears that the python memory allocation continuously increases until all ram is consumed, even if the extracted values are not being collected (or are overwriting the same variable).
I noticed this when extracting raster data at point locations, when using a large point dataset, even though I had pre-allocated a numpy array to receive the results.
Below is an example on the nc_spm_08_grass7 example data (in the landsat mapset), repeating the operation say 50 times on the same point vector dataset. I wouldn't have expected the memory consumption to continuously increase for this operation, because I'm overwriting the 'arr' variable each time. However, if you repeat this enough times, you will run out of system memory and the allocated memory does not appear to be released, i.e. even if you manually force garbage collection.
Any suggestions?
from grass.pygrass.vector import VectorTopo
from grass.pygrass.raster import RasterRow
from grass.pygrass.modules.shortcuts import raster as r
from grass.pygrass.gis.region import Region
from grass.pygrass.utils import get_raster_for_points
On Sat, Feb 9, 2019 at 5:39 PM Steven Pawley <dr.stevenpawley@gmail.com> wrote:
Hello devs,
Do you see a chance to run valgrind on this? (maybe there are more
appropriate tools in the Python world):
Any suggestions?
