[GRASS-dev] method does not change the output v.surf.bspline
Dear all,
Running v.surf.bspline using the bicubic or bilinear method yields the same results (running grass 7.8.4 dev on Linux).
To reproduce using the nc_spm_08_grass7 data set:
g.region -a vector=precip_30ynormals res=1000
v.surf.bspline input=precip_30ynormals column=jan raster_output=bspline01 ew_step=40000 ns_step=40000 method=bicubic
v.surf.bspline input=precip_30ynormals column=jan raster_output=bspline02 ew_step=40000 ns_step=40000 method=bilinear
Am I missing something?
With kind regards,
Paulo
On Mon, Jun 22, 2020 at 12:49 PM Paulo van Breugel
<p.vanbreugel@gmail.com> wrote:
Dear all,
Please try
https://github.com/OSGeo/grass/pull/727
The method selector lacked an update after method renaming.
Best,
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
Hi Markus,
Thanks. I’ll like to try out, but I am not sure how this works. Do I need to recompile grass gis? But how to incorporate the pull request? Sorry, not very familiar with the procedure?
Best regards,
Paulo
Dear all,
Please try
Best,
Markus Neteler, PhD
Hi Paulo,
On Mon, Jun 22, 2020 at 4:19 PM Paulo van Breugel
Hi Markus,
Thanks. I'll like to try out, but I am not sure how this works. Do I need to recompile grass gis? But how to incorporate the pull request? Sorry, not very familiar with the procedure?
That's pretty easy:
# go to wherever your local source code copy is:
cd grass78_git_src/
# fetch diff of pull request:
wget https://github.com/OSGeo/grass/pull/727.diff
# apply diff
git apply 727.diff
# check for the change
git status
# ... this should show: `modified: vector/v.surf.bspline/main.c`
# compile it
cd vector/v.surf.bspline/
make
# ONLY in case you always do `make install`
# (e.g. I don't since I use it directly from `bin.x86_64-pc-linux-gnu/grass78`)
cd ../../
sudo make install
# to revert the local change (needed after merge of PR, to be able to
locally update):
git apply 727.diff --reverse
HTH,
PS: see also
https://trac.osgeo.org/grass/wiki/HowToGit#Applyingadifffilelocally
