Hello guys,
I am sending my second report regarding the GRASS mini-project which is also available here: [1].
1) What did I complete this week?
I was mainly working on PR [2] dealing with dock/undock map display functionality. This PR is finished and waits for the final review. Further, I started to work on the Console reorganization topic, specifically, I have set up the new PR [3] replacing the togglable “Log file” button with the “Export history” button. This initial step is going to better steer the direction of the Console reorganization.
2) What am I going to achieve for next week?
I plan to merge both above-mentioned PRs and proceed to work on the Console reorganization topic according to Issue [4]. Not only it involves the widget reorganization itself, but it also improves user experience by adding >>> to the command prompt window.
3) Is there any blocking issue?
No, it isn’t.
Have a nice week and feel free to share any comments/suggestions.
Linda
[1] https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/ImprovingSingleWindowUX
[2] https://github.com/OSGeo/grass/pull/2667
