[GRASS-dev] Miss d.split.frame
I miss d.split.frame, to do draw many maps in one image
(somethiing like
https://grasswiki.osgeo.org/wiki/File:Mean_monthly_global_rad_maps_over_a_study_area_in_central_Greece.png).
Is anybody using successfully `d.frame` with `-c` successfully
currently?
Thank you, Nikos
Hi Nikos,
Last time I used it was for teaching. See here: https://www.github.com/veroandreo/grass_opengeohub2019/tree/master/code%2Flst_time_series_code.sh (line 304 onwards)
I found the example in a workshop by Vashek, IIRC.
HTH,
Vero
El jue., 10 dic. 2020 14:24, Nikos Alexandris <nik@nikosalexandris.net> escribió:
(somethiing like
Is anybody using successfully d.frame with -c successfully
currently?
Thank you, Nikos
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Thank you Vero!
I did not manage to make `d.frame` to work. I have ever since 2013 weird
setups and (the) Terminology (terminal) on my Funtoo-boxes and `d.mon`
segfaults ever since.
However, your link made me re-read the 'RENDER' environment variables
and I managed to make some proof-of-concept using the
GRASS_RENDER_FRAME environment variable. I hope to develop
the custom functions I need to help me type less commands.
I'll probably share these at some point along with my other tygrass
commands (https://gitlab.com/NikosAlexandris/tygrass).
Cheers, Nikos
* Veronica Andreo <veroandreo@gmail.com> [2020-12-10 14:49:50 -0300]:
Hi Nikos,
(line 304 onwards)
HTH,
Vero
(somethiing like
currently?
Thank you, Nikos
Nikos Alexandris | Remote Sensing & Geomatics
GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
