[GRASS-dev] missing dependency on Ubuntu
I just installed GRASS7.8.2 from packages on Ubuntu bionic (18.04) and g.extension fails with
ModuleNotFoundError: No module named ‘distutils.dir_util’
It is confusing, because distutils are part of standard Python, but that particular import failed.
I had to install python3-distutils package to fix that. I suppose python3-distutils should be added as a dependency?
Anna
Hi Anna,
Thanks for the feedback, I will add the dependency.
Best,
Angelos
On 1/15/20 4:51 PM, Anna Petrášová wrote:
ModuleNotFoundError: No module named 'distutils.dir_util'
Anna
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Angelos Tzotsos, PhD
Charter Member
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
cherry-pick this:
https://salsa.debian.org/debian-gis-team/grass/commit/c14b137bef39ef2aa9bc27b5f658259dfb582ff8
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
distutils was moved to the python3-stdlib-extensions package in
3.6.4~rc1-2, this source package also includes tk, gdbm & lib2to3.
Kind Regards,
Bas
Thanks Bas.
cherry-pick this:
Kind Regards,
Bas
Charter Member
New package in UbuntuGIS experimental. I will copy to Unstable in a while.
On 1/15/20 6:09 PM, Angelos Tzotsos wrote:
Thanks Bas.
cherry-pick this:
Kind Regards,
Bas
Charter Member
Thanks for the quick response!
Anna
On Wed, Jan 15, 2020 at 4:24 PM Angelos Tzotsos <gcpp.kalxas@gmail.com> wrote:
Thanks Bas.
cherry-pick this:
Kind Regards,
Bas
Charter Member
