[GRASS-dev] missing grass configuration files
Where is GRASS saving its configuration preferences now?
A short while back, Martin switched the location of the wxGUI configuration files to ~/.grass7/wx. After a bug fix for preferences saving Sunday, this is working fine.
But where is the .grassrc7 file or its equivalent?
Nothing is being created in the ~/.grass7 directory and I no longer have a .grassrc7 file. Init.sh refers to $GRASS_CONFIG_DIR, but this does not seem to be set when I check it from the GRASS terminal. BUT GRASS starts up with some kind of configuration because it saves my mapset/location preferences. So where is this?
Michael
C. Michael Barton
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
I found the file. It is now called “rc” but it is not ending up in ~/.grass7. Instead, it is just going into HOME.
So this is a bug somewhere, but I’m not sure where. In Init.sh?
Michael
Michael
C. Michael Barton
USA
Just curious - I haven't looked at the config folder changes yet: is the config folder path configurable at compile time or runtime? What would be nice is to set platform-specific locations, like ~/Library/Preferences/grass7 on OSX, instead of the non-Mac-like hidden dot folder.
And not just hidden folders, but files also, like .grassrc7.
On Dec 8, 2009, at 12:12 PM, Michael Barton wrote:
I found the file. It is now called "rc" but it is not ending up in ~/.grass7. Instead, it is just going into HOME.
So this is a bug somewhere, but I'm not sure where. In Init.sh?
Michael
Michael
______________________________
C. Michael Barton
USA
grass-dev mailing list
grass-dev@lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
That would work OK AFAIC. I also just learned that all those file that were being searched for by the startup script are also ending up in HOME instead of either Application Support or .grass7.
I guess I'd lean toward the .grass7 solution. This is not like "real" Mac programs, but a number of cross-platform Mac programs do this.
Here is what is bring this up. We have a Java based ABM that interacts with GRASS. It needs to access the GRASS configuration files and to set the environment for GRASS in order to run correctly with GRASS. This has changed rather dramatically with GRASS 7 (I'm sending a separate post on a related question).
Wherever this stuff goes, it needs to be in a place that it can be easily 'found' across platforms in a consistent way. It could be a path stored in an environmental variable, for example if that is accessible.
Michael
C. Michael Barton
USA
Michael
Michael
C. Michael Barton
USA
grass-dev Info Page
lib/init/*.
lib/init/Makefile replaces @GRASS_CONFIG_DIR@ with $(GRASS_CONFIG_DIR)
in init.sh, grass.py and init.bat. However:
1. init.sh uses $GRASS_CONFIG_DIR, but doesn't define it; it needs a
line like:
  GRASS_CONFIG_DIR=@GRASS_CONFIG_DIR@
GISRC is defined as:
  GISRCRC="$HOME/$GRASS_CONFIG_DIR/rc"
so the missing definition for GRASS_CONFIG_DIR causes it to be set to
"$HOME//rc".
2. init.bat doesn't even reference it, so substituting is pointless.
The grass.py script is correct:
  grass_config_dir = os.path.join(os.getenv('HOME'), "@GRASS_CONFIG_DIR@")
On Unix, you get grass70 (Python) and grass70.sh (Bourne shell). On
Windows, you get grass70.py, grass70.sh and grass70.bat; if you don't
give an extension, which one gets used presumably depends upon
%PATHEXT%.
The "active" version should still be created as
/tmp/grass7-<user>-<pid>/gisrc, but that will only happen if the
$GISRCRC file (should be ~/.grass7/rc but is ~/rc due to this bug)
exists.
lib/init/*.
line like:
"$HOME//rc".
Or better
if [ ! "$GRASS_CONFIG_DIR" ] ; then
  export $GRASS_CONFIG_DIR
fi
so it can be overridden by the grass startup to define a build-specific location.
...which I just added in r39949.
Michael - I also updated the scripts that were using the old user addon paths, and made the startup override GRASS_CONFIG_DIR so that it's in the user's Preferences folder on OSX instead of the hidden folder (also more secure).
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
Thanks a million. This project is so great.
Michael
C. Michael Barton
Phone: 480-965-6262
Fax: 480-965-7671
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
lib/init/*.
line like:
"$HOME//rc".
Or better
fi
- Tarzan, on war
2009/12/8 Michael Barton <michael.barton@asu.edu>:
No, it's desired feature - to store all GRASS config files on one place.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
