Hi Martin,
would be possible to upload logs of addon compilation on Windows? I think they used to be there at one point. I am trying to figure out what’s wrong with compilation of r.futures.
Anna
Hi Martin,
Anna
Hi Anna,
po 25. 11. 2019 v 16:49 odesílatel Anna Petrášová
<kratochanna@gmail.com> napsal:
would be possible to upload logs of addon compilation on Windows? I think they used to be there at one point. I am trying to figure out what's wrong with compilation of r.futures.
logs are available [1]. Apparently broken, I will take a look ASAP.
Martin
[1] https://wingrass.fsv.cvut.cz/grass79/x86_64/addons/grass-7.9.dev/logs/
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
po 25. 11. 2019 v 18:32 odesílatel Martin Landa <landa.martin@gmail.com> napsal:
BTW, logs for 7.8.1 looks better
https://wingrass.fsv.cvut.cz/grass78/x86_64/addons/grass-7.8.1/logs/
Ma
Martin Landa
Seems modules that import numpy fail to build…
Fra: grass-dev grass-dev-bounces@lists.osgeo.org på vegne av Martin Landa landa.martin@gmail.com
Sendt: mandag 25. november 2019 18:34
Til: Anna Petrášová kratochanna@gmail.com
Kopi: GRASS-dev grass-dev@lists.osgeo.org
Emne: Re: [GRASS-dev] missing logs for Windows addons
po 25. 11. 2019 v 18:32 odesílatel Martin Landa landa.martin@gmail.com napsal:
Ma
Martin Landa
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
This is still an issue, in case of 7.8.1 it can’t find numpy, e.g.
https://wingrass.fsv.cvut.cz/grass78/x86_64/addons/grass-7.8.1/logs/r.futures.log
in case of 7.8.dev and 7.9 everything fails due to:
Fatal Python error: initfsencoding: unable to load the file system codec
File "C:/OSGeo4W64/apps/Python27\lib\encodings\__init__.py", line 123
raise CodecRegistryError,\
SyntaxError: invalid syntax
which seems to be some python 2/3 mismatch, e.g.:
https://trac.osgeo.org/osgeo4w/ticket/547
On Mon, Nov 25, 2019 at 7:59 PM Stefan Blumentrath <Stefan.Blumentrath@nina.no> wrote:
Fra: grass-dev <grass-dev-bounces@lists.osgeo.org> på vegne av Martin Landa <landa.martin@gmail.com>
Til: Anna Petrášová <kratochanna@gmail.com>
Kopi: GRASS-dev <grass-dev@lists.osgeo.org>
Emne: Re: [GRASS-dev] missing logs for Windows addonspo 25. 11. 2019 v 18:32 odesílatel Martin Landa <landa.martin@gmail.com> napsal:
Ma
Martin Landa
čt 2. 1. 2020 v 20:08 odesílatel Anna Petrášová <kratochanna@gmail.com> napsal:
This is still an issue, in case of 7.8.1 it can't find numpy, e.g.
fixed [1].
Should be better [2], r.futures compiled [3]. Ma
[1] https://wingrass.fsv.cvut.cz/grass78/x86_64/addons/grass-7.8.1/logs/r.futures.log
[2] https://wingrass.fsv.cvut.cz/grass79/x86_64/addons/grass-7.9.dev/logs/
[3] https://wingrass.fsv.cvut.cz/grass79/x86_64/addons/grass-7.9.dev/logs/r.futures.log
Martin Landa
Thanks for looking into this! Unfortunately, there is now a different problem, in 7.8 and 7.9, it looks like all c modules are not compiled, that’s also the case of r.futures.pga (which is a c module within r.futures):
make -C r.futures.pga || echo /c/msys64/usr/src/grass-addons/grass7/raster/r.futures/r.futures.pga >> /usr/src/grass782/error.log
make[1]: Entering directory '/c/msys64/usr/src/grass-addons/grass7/raster/r.futures/r.futures.pga'
test -d OBJ.x86_64-w64-mingw32 || mkdir -p OBJ.x86_64-w64-mingw32
gcc -I/c/OSGeo4W64/include -g -O2 -I/c/OSGeo4W64/include -I/usr/src/grass782/dist.x86_64-w64-mingw32/include -I/usr/src/grass782/dist.x86_64-w64-mingw32/include -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\" -I/usr/src/grass782/dist.x86_64-w64-mingw32/include -I/usr/src/grass782/dist.x86_64-w64-mingw32/include -DRELDIR=\"/c/msys64/usr/src/grass-addons/grass7/raster/r.futures/r.futures.pga\" -o OBJ.x86_64-w64-mingw32/keyvalue.o -c keyvalue.c
/bin/sh: gcc: command not found
make[1]: *** [/c/msys64/usr/src/grass782/include/Make/Compile.make:32: OBJ.x86_64-w64-mingw32/keyvalue.o] Error 127
On Fri, Jan 3, 2020 at 3:13 PM Martin Landa <landa.martin@gmail.com> wrote:
fixed [1].
[3] https://wingrass.fsv.cvut.cz/grass79/x86_64/addons/grass-7.9.dev/logs/r.futures.log–
Martin Landa
Ahoj,
po 6. 1. 2020 v 9:42 odesílatel Anna Petrášová <kratochanna@gmail.com> napsal:
Thanks for looking into this! Unfortunately, there is now a different problem, in 7.8 and 7.9, it looks like all c modules are not compiled, that's also the case of r.futures.pga (which is a c module within r.futures):
ops, opraveno. Martin
Martin Landa
On 6/01/20 13:29, Martin Landa wrote:
Ahoj,
I see that r.object.activelearning also fails with:
"ModuleNotFoundError: No module named 'scipy'"
Should this module be changed somehow to wrap the import in a way to only make it fail at runtime ? ISTR, there was a technique for that, or ?
Moritz
Hi Moritz,
po 6. 1. 2020 v 16:56 odesílatel Moritz Lennert <mlennert@club.worldonline.be> napsal:
“ModuleNotFoundError: No module named ‘scipy’”
A lazy import should do this for you.
Thanks!
On Mon, Jan 6, 2020 at 1:30 PM Martin Landa <landa.martin@gmail.com> wrote:
Ahoj,
Martin Landa
Hi, coming back to this… the addons don’t seem to be updated, I checked 2 addons and no recent changes are incorporated in the zip files. Is it possible you still download it from trac rather than github?
Thanks!
On Mon, Jan 6, 2020 at 12:10 PM Ondřej Pešek <pesej.ondrek@gmail.com> wrote:
Hi Moritz,
only make it fail at runtime ? ISTR, there was a technique for that, or ?A lazy import should do this for you.
pá 24. 1. 2020 v 16:16 odesílatel Anna Petrášová <kratochanna@gmail.com> napsal:
Hi, coming back to this... the addons don't seem to be updated, I checked 2 addons and no recent changes are incorporated in the zip files. Is it possible you still download it from trac rather than github?
which GRASS version? Ma
Martin Landa
On Tue, Jan 28, 2020 at 4:59 AM Martin Landa <landa.martin@gmail.com> wrote:
I looked at 7.9, 7.8.2 and 7.8.dev, none of them have any recent changes
Anna
Martin Landa
I found another issue, it’s not a big deal, but addons can’t be installed for grass7.8dev because the g.extension expects grass-7.8.3dev while the server uses grass-7.8.dev:
ERROR: Cannot open URL: http://wingrass.fsv.cvut.cz/grass78/x86_64/addons/grass-7.8.3dev/r.futures.zip
Anna
On Tue, Jan 28, 2020 at 9:00 AM Anna Petrášová <kratochanna@gmail.com> wrote:
Anna
Martin Landa
Seems like the server is down right now…
On Fri, Feb 14, 2020 at 2:15 PM Anna Petrášová <kratochanna@gmail.com> wrote:
Anna
Anna
Martin Landa
pá 14. 2. 2020 v 20:15 odesílatel Anna Petrášová <kratochanna@gmail.com> napsal:
I found another issue, it's not a big deal, but addons can't be installed for grass7.8dev because the g.extension expects grass-7.8.3dev while the server uses grass-7.8.dev:
the correct URL is
http://wingrass.fsv.cvut.cz/grass78/x86_64/addons/grass-7.8.dev/r.futures.zip
Ma
Martin Landa
út 28. 1. 2020 v 15:00 odesílatel Anna Petrášová <kratochanna@gmail.com> napsal:
please check a next build (1/3), should be fixed.
Ma
Martin Landa
Thanks, confirmed!
On Sat, Feb 29, 2020 at 4:52 PM Martin Landa <landa.martin@gmail.com> wrote:
Ma
Martin Landa
On Sat, Feb 29, 2020 at 4:51 PM Martin Landa <landa.martin@gmail.com> wrote:
the correct URL is
yes, but g.extension expects grass-7.8.3dev because grass.version() gives 7.8.3dev not 7.8.dev. So I guess the directory layout should follow that.
Ma
Martin Landa
