Devs,
is there a reason for r.texture missing the overwrite flag? In G7,
Flags:
-s Separate output for each angle (0, 45, 90, 135)
-a Calculate all textural measurements
–v Verbose module output
–q Quiet module output
Nikos
Devs,
Flags:
Nikos
Yes, the output is not defined as raster map.
This should add the --o option (untested).
--- main.c (Revision 57260)
+++ main.c (Arbeitskopie)
@@ -109,10 +109,9 @@
opt_input = G_define_standard_option(G_OPT_R_INPUT);
- opt_output = G_define_option();
+ opt_output = G_define_standard_option(G_OPT_R_OUTPUT);
opt_output->key = "prefix";
- opt_output->type = TYPE_STRING;
- opt_output->required = YES;
+ opt_output->multiple = YES;
opt_output->description = _("Prefix for output raster map(s)");
opt_size = G_define_option();
Be aware that the test to overwrite an existing map works only for the
base map name, not for output maps that are build from the base map
name and an increment.
Best regards
Soeren
2013/8/12 Nikos Alexandris <nik@nikosalexandris.net>:
Devs,
Flags:
--v Verbose module output
--q Quiet module output
Nikos
grass-dev mailing list
grass-dev@lists.osgeo.org
These multiple output maps are general problem for grass. Some modules have
this prefix (or better say basename) option and some other have it in some
undefined state such as r.in.gdal can output multiple maps if the input is
multiple bands. This is the problem in the GUI since we don't know which
map(s) should we add (if Add maps to layer list is checked). Some solution
is needed...
