[GRASS-dev] Missing package "six" for Windows compilation
Hello GRASS developers,
The “six” python package, required by Matplotlib, seems to be missing on the Windows side. As a result, all packages requiring it are throwing errors. For example, as seen at http://wingrass.fsv.cvut.cz/grass72/x86/addons/latest/logs/:
  File "C:/Users/landa/grass_packager/grass722/x86/addons/v.faultdirections/scripts/[v.faultdirections.py](http://v.faultdirections.py)", line 50, in <module>
    import matplotlib #required by windows
  File "C:\OSGeo4W32\apps\Python27\lib\site-packages\matplotlib\__init__.py", line 105, in <module>
    import six
<b>ImportError: No module named six
</b>/c/msys32/usr/src/grass722/include/Make/Html.make:14: recipe for target 'v.faultdirections.tmp.html' failed
make: *** [v.faultdirections.tmp.html] Error 1
rm v.faultdirections.tmp.html
Could someone with permissions please install this and test with an “import matplotlib”?
Thank you!
Andy
The "six" python package, required by Matplotlib, seems to be missing on
  File
"C:/Users/landa/grass_packager/grass722/x86/addons/v.faultdirections/scripts/v.faultdirections.py",
line 50, in
<module>
  File
line 105, in
<module>
    import six*ImportError: No module named six
*/c/msys32/usr/src/grass722/include/Make/Html.make:14: recipe for
"import
matplotlib"?
Thank you!
it's interesting, as e.g. r.hypso which also uses matplotlip builds in
winGRASS64bit addon
https://wingrass.fsv.cvut.cz/grass73/x86_64/addons/grass-7.3.svn/logs/
but fails in winGRASS32bit addon:
https://wingrass.fsv.cvut.cz/grass73/x86/addons/grass-7.3.svn/logs/
the same for v.faultdirections, it builds in winGRASS64bit addon
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
Interesting. I noticed this while working on some codes for GSFLOW, the USGS groundwater–surface water module, and found a Tkinter missing error message in those for GRASS 7.3 64-bit:
  File "C:/Users/landa/grass_packager/grass73/x86_64/addons/v.gsflow.export/scripts/[v.gsflow.export.py](http://v.gsflow.export.py)", line 108, in <module>
    from matplotlib import pyplot as plt
  File "C:\OSGeo4W64\apps\Python27\lib\site-packages\matplotlib\pyplot.py", line 115, in <module>
    _backend_mod, new_figure_manager, draw_if_interactive, _show = pylab_setup()
  File "C:\OSGeo4W64\apps\Python27\lib\site-packages\matplotlib\backends\__init__.py", line 32, in pylab_setup
    globals(),locals(),[backend_name],0)
  File "C:\OSGeo4W64\apps\Python27\lib\site-packages\matplotlib\backends\backend_tkagg.py", line 6, in <module>
    from six.moves import tkinter as Tk
  File "C:\OSGeo4W64\apps\Python27\lib\site-packages\six.py", line 203, in load_module
    mod = mod._resolve()
  File "C:\OSGeo4W64\apps\Python27\lib\site-packages\six.py", line 115, in _resolve
    return _import_module(self.mod)
  File "C:\OSGeo4W64\apps\Python27\lib\site-packages\six.py", line 82, in _import_module
    __import__(name)
<b>ImportError: No module named Tkinter
</b>/c/msys64/usr/src/grass_trunk/include/Make/Html.make:14: recipe for target 'v.gsflow.export.tmp.html' failed
make: *** [v.gsflow.export.tmp.html] Error 1
rm v.gsflow.export.tmp.html
Matplotlib wasn’t needed for these modules (it’s part of my standard set of imports, which I copied/pasted), so I removed it and they should hopefully compile fine the next time the server builds everything. But there is some underlying package problem…
Andy
File
“C:/Users/landa/grass_packager/grass722/x86/addons/v.faultdirections/scripts/v.faultdirections.py”,
line 50, in
File
“C:\OSGeo4W32\apps\Python27\lib\site-packages\matplotlib_init_.py”,
line 105, in
target ‘v.faultdirections.tmp.html’ failed
“import
matplotlib”?
Thank you!
it’s interesting, as e.g. r.hypso which also uses matplotlip builds in
winGRASS64bit addon
best regards
Helmut
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
But there is some underlying package problem...
it seems six is in the winGRASS 64bit build environment, but not in the
winGRASS 32bit build environment.
best regards
Helmut
How about tkinter on Win64?
**ImportError: No module named Tkinter**
best regards
Helmut
which addon?
https://wingrass.fsv.cvut.cz/grass73/x86_64/addons/grass-7.3.svn/logs/v.faultdirections.log
v.faultdirections builds on 64 bit
best regards
Helmut
which addon?
tested in OSGeo4W's python 64bit:
C:\>python
Python 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)] on
win32
Type "help", "copyright", "credits" or "license" for more information.
from Tkinter import *
best regards
Helmut
Module: [v.gsflow.export.py](http://v.gsflow.export.py/)
See: https://wingrass.fsv.cvut.cz/grass73/x86_64/addons/grass-7.3.svn/logs/v.gsflow.export.log
But I have removed the matplotlib import, so this may disappear upon the next build.
Andy
which addon?
tested in OSGeo4W’s python 64bit:
C:>python
win32
Type “help”, “copyright”, “credits” or “license” for more information.
best regards
Helmut
