[GRASS-dev] missing programmer's manual?
I wanted to look in the programer's manual in case call from TclTk to C for NVIZ are listed somewhere. I'm not optimistic, but it's worth checking. I went to the on-line development page to find it <http://grass.osgeo.org/devel/index.php#prog >. The link to the on-line html works fine. But went I went to try to download something, I ran into trouble. The on-line PDF for download link goes to a blank page <http://download.osgeo.org/grass/grass6_progman_pdf/ >. I'm also directed to go to the download page, and there is a link to down load the manual. But the link takes me back to the development page. There is a note that I can create my own from source, but when I try, I find out that I'll need to install doxygen first. I haven't yet tried that, but it seems that a downloadable version ought to be accessible somewhere.
Michael
On Thu, Jan 1, 2009 at 12:16 AM, Michael Barton <michael.barton@asu.edu> wrote:
<http://grass.osgeo.org/devel/index.php#prog&gt;\. The link to the on-line html
<http://download.osgeo.org/grass/grass6_progman_pdf/&gt;\.
The PDF cronjob is actually broken. I'll look into this.
I guess I found it. The directory should be now populated with PDFs over
the next hour.
However, NVIZ isn't documented with doxygen, basically the GRASS libs
are.
the next hour.
are.
Thanks. I found a fix for loading 3D points to nviz from the command line without first loading a surface. Just committed to 35144 db6,
35145 rb, and 35146 trunk.
the next hour.
are.
Is NVIZ documented anywhere?
Michael
