[GRASS-dev] missing proj-parms.table in GRASS 7
i don't know if this is a bug or a 'feature'.
Recently, the location wizard stopped running in GRASS 7 because proj-parms.table is missing from $GISBASE/etc. Here is the error.
IOError: [Errno 2] No such file or directory: '/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/proj-parms.table'
So does this mean there is a bug that is preventing this file from getting created or copied to the correct spot in GRASS 7?
Or does it mean that proj-parms.table has been replaced with something else and we need to change the location wizard to parse the new file, whatever it is?
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 SHESC), 480-727-0709 (CSDC)
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
proj-{desc,parms,units}.table are part of g.setproj. g.setproj isn't
built in 7.0, as it's a terminal-based interactive program, so those
files don't get installed. This has been the case for a long time; it
isn't a recent change.
The files could be moved to e.g. lib/proj.
Well, we need what is in this file to correctly create a full proj4 string. It's easy to change where the location manager looks for files, but they need to be built.
Specifically, the following files are read by the __readData method of the LocationWizard class to create the lists and dictionaries needed for the wizard.
proj-parms.table
datum.table
ellipse.table
proj-desc.table
Michael
the wizard.
proj-parms.table
datum.table
ellipse.table
proj-desc.table
I've moved proj-*.table from g.setproj to lib/proj in r40557.
datum.table and ellipse.table are from lib/gis, and are already
installed.
Thanks much.
Michael
______________________________
C. Michael Barton
Tempe, AZ 85287-2402
USA
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
    http://www.public.asu.edu/~cmbarton
the wizard.
proj-parms.table
datum.table
ellipse.table
proj-desc.table
installed.
