[GRASS-dev] MODIS import in GRASS6.4
I have been using MODIS datasets in MRT tool and MATLAB but Now I want to import MODIS projected datasets to GRASS .
At http://grass.osgeo.org/wiki/MODIS is described methods to do this. But I have a few (quick) questions. Thanks for your help
Question 1: can those methods be applied using a GRASS Script? (I believe so)
Question 2: in method 1 (http://grass.osgeo.org/wiki/MODIS#Method_1), It’s said to create a Project/mapset with EPSG 3266. Why that system? And Why if gdal_translate will create geotiff in EPSG4326?
Question 3: Regarding a_ullr. This flag asks for Upperleft and lowerright. This means that those values are the same for all files. But in the case that they may vary. How can I obtain them from MODIS Metadata/header? And this would mean that the we are dealing with a regular dataset because in a Geostationary dataset this wouldn’t be possible (I guess).
Question 4: What is the –co flag? I read Gdal_translate description but I didn’t find it very clear…
Question 5: As far as I can see, Geotiff format is used as an intermediate format in order to import data to GRASS. Why is it chosen?
Question 6: Since GDAL does not automatically georeference HDF4 images, is there a list of the formats that GDAL automatically georreference?
Question 7: if we define a_ullr, this means that GCP points are not being used right?
Regarding method 2, that is based on GRASS6.5, will this be implemented for grass 6.4? (the –i flag)
Thank you
See ya
Franz
Thank you
See ya
Franz
On Thu, Feb 18, 2010 at 4:38 PM, Franz Schiller
Quick questions yes, but not so easy to answer!
so)
yes and no: I use MRT in batch mode within a GRASS script. Not sure
if this answers your question.
I personally stick with
http://grass.osgeo.org/wiki/MODIS#Method_0
The gdal way is too messy for me.
They should be in the XML file.
And
Geostationary (Terra and Aqua are polar orbiting)? not sure what you mean.
didn’t find it very clear..
-co: compression of resulting file
Feel free to improve the Wiki page.
Because it is well known. You can chose whatever you like and works.
Yes:
http://www.gdal.org/formats_list.html
used right?
I have no idea (since I prefer MRT).
I guess in 6.4.1 if it can be backported.
Markus answered most of these, but I'll throw in another 2c.
(I believe so)
(yes)
It says you might try that, not that you definitely should.
EPSG:32662 is "Plate Carree"
# WGS 84 / Plate Carree
<32662> +proj=eqc +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_
defs <>
A number of global datasets ship in this. With ~4km pixels a possible
datum error of 150m away from the wgs84 DATUM isn't going to be very
noticeable. but a switch between the wgs84 ELLIPSOID and a perfect
sphere can lead to errors of ~25km.
Consult your metadata. Hopefully it gives some guidance (often it
doesn't though, hence the confusion).
Question 3:
parse gdalinfo or as Markus suggested the associated XML file?)
Question 4:
but I didn’t find it very clear..
see the r.out.gdal help page for more on compression.
if gdalinfo can see GCPs but not map bounds, use 'gdalwarp -tps' to
apply the GCPs and make a georeferenced image which can be loaded into
grass.
flag)
if no problems are reported in testing it will be backported to 6.4.1.
Hamish
