They are good candidates to use both module->label and
module->description. Using both of those is not an error. If the GUI or
lib/parser.c fails to deal with that, the bug is not in the module.
Just like with option descriptions, when ->label is present it becomes
the short GUI label and ->description then becomes the longer tooltip
text.
In the case where helpful information is removed from one place, care
must be taken to add it back in somewhere else.
I am not sure about using tooltips for module description (i.e.
label/description). The tooltip can be moved to the manual page
('description' section). See [1].
Hamish wrote:
> I notice these two changes: (are there more?)
> http://trac.osgeo.org/grass/changeset/25463
> http://trac.osgeo.org/grass/changeset/29533
> GUI or lib/parser.c fails to deal with that, the bug is not in the
> module.
Martin:
ok, if you follow the thread view from that post you can see Glynn's
replies of Sep 8, 2007 and Mar 23, 2007 which should help explain it.
The dual role of ->description is a bit confusing at first but makes
some sense once it is explained.
A module's (or option's) sub-title need not be shown or thought of as a
tooltip. e.g. --help, --html-description, the TclTk GUI and
tools/module_synopsis.sh all handle it well. For module options, making
it into a tooltip is just a handy thing to do with it. I would hope
wxGUI would handle module->label in a similar way to the TclTk GUI
(unfortunately I still wait for Debian+wx2.8 issues to be resolved
before I can help).
If the information is important enough to be used as a subtitle, by all
means it should be mentioned in the help page as well.
> care must be taken to add it back in somewhere else.
The tooltip (module->description) has been moved to the manual page.
I saw that, I was wondering about r29533. (I see you've now corrected
that, thanks)
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs
> > module.
before I can help).
The wxGUI would handle module->label as well, it is trivial issue. I
am not sure, should I revert these two changes (to add module->label)?
