This remains puzzling. On my MacBook with Lion, I have the following:
Michaels-MacBook-Air:~ cmbarton$ echo $LC_CTYPE
Michaels-MacBook-Air:~ cmbarton$ echo $LC_ALL
Michaels-MacBook-Air:~ cmbarton$ echo $LANG
en_US.UTF-8
Michaels-MacBook-Air:~ cmbarton$ echo $LC_MESSAGE
Michaels-MacBook-Air:~ cmbarton$ python
Python 2.7.1 (r271:86832, Jun 25 2011, 05:09:01)
[GCC 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2335.15.00)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
import locale
locale.getdefaultlocale()
('en_US', 'UTF8')
On Carlos' MacBook with Lion (without setting LC_CTYPE in .profile), we get the following:
MacBook-Pro-de-Carlos:~ carlosrodriguezrellan$ echo $LC_CTYPE
UTF-8
MacBook-Pro-de-Carlos:~ carlosrodriguezrellan$ echo $LC_ALL
MacBook-Pro-de-Carlos:~ carlosrodriguezrellan$ echo $LANG
MacBook-Pro-de-Carlos:~ carlosrodriguezrellan$ echo $LC_MESSAGE
MacBook-Pro-de-Carlos:~ carlosrodriguezrellan$ python
Python 2.7.1 (r271:86832, Jul 31 2011, 19:30:53)
import locale
File "<stdin>", line 1, in <module>
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py", line 496, in getdefaultlocale
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py", line 428, in _parse_localename
ValueError: unknown locale: UTF-8
So by default, my LANG is set but none of the other locale variables are set. For Carlos, LC_CTYPE is set (incorrectly??) and nothing else (including LANG) is set.
Neither one of us have explicitly set any of these locale variables prior to hitting this issue. Since another Spanish colleague (Agustin) also reported problems, I wonder if this is something that is "normal" for Spanish-enabled Macs.
An error trap on locale.getdefaultlocale() and setting the language explicitly in wx (rather than depending on the system locale variables), as I think the intent is, would fix this problem.
Adding an error trap to locale.getdefaultlocale() is easy (I would use try/except); fixing the GUI to use the wx configuration file instead of .grassrc6 is somewhat more labor.
MIchael
On Jul 28, 2012, at 1:08 AM, Hamish wrote:
Michael wrote:
So I think there needs to be an error trap at this point for
"locale.getdefaultlocale()" and a default fallback to
English.
perhaps better, fall back to "C" aka unset.
fwiw, on linux with python 2.4.4 and 2.6.6, 2.7.3, all give:
import locale
(None, None)
lang = '.'.join(locale.getdefaultlocale())
TypeError: sequence item 0: expected string, NoneType found
when the parent shell has LANG=C set.
with LANG=en_US.UTF-8 at the shell, the above gives:
locale.getdefaultlocale() = ('en_US', 'UTF-8')
lang = 'en_US.UTF-8'
the tuple it returns is (language code, encoding).
locale — Internationalization services — Python 3.12.7 documentation
perhaps add something like:
if locale.getdefaultlocale()[0] is None:
lang = None
else:
note,
What is the correct way to set Python's locale on Windows? - Stack Overflow
so fallback to a common language setting may also have to be platform
dependent. dunno what Windows makes of LANG=C.
One thing that I notice is that nothing seems to be
reading the language setting in the wx file, where
preferences sets it. I thought the idea was to make this a
GUI preference. So perhaps, this also needs to be changed to
read the preferences file instead of .grassrc6.
sounds reasonable to me, but I wasn't following along & have not
heard it described how the new system is supposed to work.
thanks for looking into this,
Hamish
_____________________
C. Michael Barton
Visiting Scientist, Integrated Science Program
National Center for Atmospheric Research &
University Consortium for Atmospheric Research
303-497-2889 (voice)
Arizona State University
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
