So this is getting narrowed down. Another question is does this just pop up as a bug with effects on the GUI in Lion or does it happen in Snow Leopard too? So far my tests have not been extensive enough.
2 Spanish computers with Lion: bad
1 English computer with Lion: good
1 English computer with Snow Leopard: good
On Jul 26, 2012, at 12:00 PM, <grass-dev-request@lists.osgeo.org>
wrote:
Date: July 26, 2012 6:26:47 AM MST
To: Michael Barton <Michael.Barton@asu.edu>, Agustin Angel Diez Castillo <agustin.diez@uv.es>
Cc: Martin Landa <landa.martin@gmail.com>, Glynn Clements <glynn@gclements.plus.com>, GRASS developers grass-developers <grass-dev@lists.osgeo.org>
Subject: Re: [GRASS-dev] more on locale problem
Reply-To: William Kyngesburye <kyngchaos@kyngchaos.com>
As you mentioned Michael, there was discussion of this problem a few times in the past.
The problem setting is not LANG, though, it’s LC_CTYPE. The system is somehow setting that to “UTF-8”, and Python checks LC_CTYPE (and LC_ALL next) before it checks LANG, so setting LANG in GRASS won’t help, as Agustin found.
On Jul 26, 2012, at 5:03 AM, Agustin Angel Diez Castillo wrote:
Michael and others,
Michael’s 6.4.3 menus aren’t working here, I did try adding
en_US.UTF-8
to .grassrc6 but the complaints are the same
ERROR: unknown locale: UTF-8
2012-07-26 11:56:43.011 Python[1916:e0f] CFURLCreateWithString was passed this invalid URL string: ‘/System/Library/CoreServices/CommonCocoaPanels.bundle’ (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
by the way my system preferences are set to english but the region is set to Spain.
cli is working
As you know in R the language is forced with
defaults write org.R-project.R force.LANG en_US.UTF-8
Is there something similar in GRASS?
A
On Thursday, July 26, 2012 08:16 CEST, Michael Barton <Michael.Barton@asu.edu> wrote:
So I am now completely baffled as to why GRASS is not working on my colleague’s computer. it is a pretty new MacBook (last 6 months) and he has not installed much on it–Office, Mendeley. It is running the most current version of Lion (10.7.4).
There are repeated problems with locale on it. Here is an example that works fine on my computer also running Lion.
import locale
locale.getdefaultlocale()
File “”, line 1, in
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py”, line 496, in getdefaultlocale
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py”, line 428, in _parse_localename
ValueError: unknown locale: UTF-8
I don’t know where it is getting UTF-8. The GUI code in GRASS calls the language en_ES.UTF-8, but this is running Python outside of GRASS. I’ve tried setting locale to es_EN, and to C. But we still get this error when locale.getdefaultlocale() is run in wx GUI.
Any ideas???
Michael
William Kyngesburye <kyngchaosatkyngchaosdotcom>
http://www.kyngchaos.com/First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don’t know. Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don’t know either. Wretched, isn’t it?-HitchHiker’s Guide to the Galaxy
