I am trying to compile yesterday's CVS sources on Win32 using MSYS and
MingW (3.4.2).
When the make script should link the gis lib objs (and other libs), I
get this:
OBJ.i686-pc-mingw32/open_misc.o(.data+0x0): In function `G__open_misc':
C:/msys/src/grass6/lib/gis/open_misc.c:45: multiple definition of `_fmode'
OBJ.i686-pc-mingw32/open.o(.data+0x0):C:/msys/src/grass6/lib/gis/open.c:98:
first defined here
collect2: ld returned 1 exit status
make[2]: ***
[/src/grass6/dist.i686-pc-mingw32/lib/libgrass_gis.6.3.cvs.dll] Error 1
I updated from CVS ca. 18 hours ago and did a "make distclean" and "make
clean" before running the configure script.
Am I doing sth. wrong here?
Best,
Benjamin
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
MingW (3.4.2).
get this:
first defined here
make[2]: ***
I've removed both occurrences of _fmode from libgis (in any case,
defining it inside a DLL doesn't work). _fmode should be defined by
linking against $(FMODE_OBJ).
Thanks, Glynn for the quick reply.
This fixed things in part. However, now I have a problem with the DBMI
lib:
cd /src/grass6/lib/db/dbmi_client
make
gives me:
gcc -I/src/grass6/dist.i686-pc-mingw32/include -I/include
-I/local/include -g -O2 -I/include -I/local/include
-DPACKAGE=\""grasslibs"\" -I../dbmi_base -DPACKAGE=\""grasslibs"\"
-I/src/grass6/dist.i686-pc-mingw32/include \
-o OBJ.i686-pc-mingw32/start.o -c start.c
start.c: In function `db_start_driver':
start.c:157: error: `have_stdin' undeclared (first use in this function)
start.c:157: error: (Each undeclared identifier is reported only once
start.c:157: error: for each function it appears in.)
start.c:157: error: `have_stdout' undeclared (first use in this function)
start.c:162: error: `stdin_fd' undeclared (first use in this function)
start.c:168: error: `stdin_orig' undeclared (first use in this function)
start.c:185: error: `stdout_fd' undeclared (first use in this function)
start.c:191: error: `stdout_orig' undeclared (first use in this function)
make[1]: *** [OBJ.i686-pc-mingw32/start.o] Error 1
make[1]: Leaving directory `/src/grass6/lib/db/dbmi_client'
Maybe something needs to be fixed in the configure script for Win32?
Benjamin
MingW (3.4.2).
get this:
first defined here
make[2]: ***
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
lib:
make
gives me:
This seems to come from Brad's latest change to start.c:
@@ -33,9 +38,6 @@
int stat;
dbConnection connection;
char ebuf[5];
- int stdin_orig, stdout_orig;
- int have_stdin, have_stdout;
- int stdin_fd, stdout_fd;
Brad, any special reason for this, or did you just not see that these are used in the #ifdef __MINGW32__ which starts at line 117 ?
Moritz
> lib:
> make
> gives me:
@@ -33,9 +38,6 @@
int stat;
char ebuf[5];
Almost certainly the latter. I've restored the variables,
conditionalised upon "#ifdef __MINGW32__" to prevent "unused variable"
warnings on other platforms (which is probably the reason that they
were removed).
OK, this seems to have done the trick.
Thanks for the quick help.
In the future, I will try to find more time to compile and test the CVS
version of GRASS more frequently on Win32, so problems like these will
surface early.
Benjamin
lib:
make
gives me:
@@ -33,9 +38,6 @@
int stat;
char ebuf[5];
were removed).
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
