I have no clue how difficult it would be to implement, but it would be great if there was the option in the cartographic composer to add more than one map frame (same goes for the other map items).
Paulo
Paulo
ps.map doesn’t support multiple map frames directly, only through eps instruction:
http://grasswiki.osgeo.org/wiki/Psmap_multi_pane_example
Composer is just a graphical front-end to ps.map. It could run ps.map on more map frames and display them via eps instruction (automate what the user has to do) but it seems to be quite a lot of work. So, so far you have to do it manually.
Anna
On Mon, May 5, 2014 at 7:14 AM, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Paulo
grass-dev mailing list
grass-dev@lists.osgeo.org
Ok, thanks for the feedback.
Paulo
