[GRASS-dev] my first grass complete script
hi this is my first grass complete grass script in C. I was trying to
draw a rectangle around the map region. The script work very well but I
can not display the vector map.
Please can you help me to find my mistake.
(attachments)
main.c (2.05 KB)
You do know that there is v.in.region ?
You could start by giving us more information such as
- how do you launch this script ?
- what is the result ? I.e. for example if a map is created by the script, what is the v.info, and possibly v.category option=report output for this file ?
Moritz
Moritz Lennert <mlennert <at> club.worldonline.be> writes:
Yes I don't know v.in.region. My purpose was not to create to something new but
to learn how to create a very simple vector map base on the region attribute.
the script will be launch into grass envir. using v.rectangle output=xxxx for
example and the map is created by the script. Please compile the script and
install it you will have every info.
for this file ?
Moritz
