Hamish:
> note that the nightly build needs some adjustment,
> grass70.bat files are making it into the 6.4 build
Helmut wrote:
in
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsiI can't see anything about grass7 there.
no; I expect it could be due to an unclean build enviroment on the
nightly build server.
the 3 files are in C:\Program Files\GRASS-64-SVN\msys\
I've tested it by building a WinGrass-Installer, there are no Grass7-files
also I notice the C:/Program Files/GRASS GIS/GRASS-6-SVN/msys/grass/ dir is empty.
see https://trac.osgeo.org/grass/ticket/629#comment:7
"The empty grass dir is a mount point for
the install directory and allows the grass with msys shortcuts
to be executed with msys.bat /grass/bin/grass64 -wxpython etc."
> and the msys.bat hacks are not applied?
> (we should just put our version in svn and overcopy it
> as part of the >packaging script)
there are 2 options for this issue:
(1) holding a copy for example in releasebranch_6_4/mswindows/osgeo4w
and replacing the osgeo4w-msys.bat version by GRASS-Packager.bat and/or NSIS-script
(2) write out msys.bat by the NSIS-installer itself
;Create the msys.bat
ClearErrors
FileOpen $0 $INSTALL_DIR\msys\msys.bat w
FileWrite $0 ...
which msys.bat-hacks?
maybe this mentionend in
http://trac.osgeo.org/grass/wiki/CompileOnWindows#RemoveOSGeo4WTracesfromPackage
these changes are clear.
yes, and in the patches here:
(so whatever Colin builds with)
Hamish
following the thread in ticket #629 isn't easy.
some comments:
- GRASS-Installer.patch is in svn, see
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi#L673
- msys.bat-version added by Colin to the report
I've built a Wingrass-Installer including this msys.bat-version, but commented out
https://trac.osgeo.org/grass/attachment/ticket/629/msys.bat#L49
rem if installed in a directory containing spaces prepare for a world of pain
rem for /F %%i IN ('echo %WD%') DO @set PART1=%%i
rem if NOT "%PART1%" == "%WD%" (
rem echo Path names containing spaces are not supported -- aborting.
rem pause
rem exit 1
rem )
because WinGrass is installed in path with spaces c:\Program Files\.
I can provide this WinGrass-Installer-version including Colin's msys.bat-version if needed?.
I've tested this WinGrass-Installer-version a little bit in WinGrass+Msys-mode:
msys-commandline is starting and working.
some examples in the msys-command-line:
- v.db.addcol, v.db.dropcol, v.db.select are working
- v.colors isn't working because the color rule "elevation" can't be find (but is
working in the self-compiled grass64 within the osgeo4w-stack)
GRASS 6.4> v.colors map=mygeology column=GEOL250_ID rgb_column=gc1 color=elevation
ls: c:/Program: No such file or directory
ls: Files/GRASS-64-SVN/etc/colors/: No such file or directory
FEHLER: Invalid color rule <elevation>
Valid options are: random grey.eq grey.log rules
best regards
Helmut
______________________________________________________
GRATIS für alle WEB.DE-Nutzer: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://movieflat.web.de
