Dear grass devs and users,
sorry for digging up this pretty old topic. It was about the end of my
initial message, see bellow (perhaps should I have opened a ticket for
it)
The question was : is it possible to add the french nad grid to grids
provided by default in grass directories ?
Everytime I completely rebuild grass (after a make distclean) I have to
manually copy the ntf_r93.gsb file
into /usr/local/grass-XX.svn/etc/proj/nad/
It would be nice that grass sources included this nad grid ; here in
France it is fundamental whenever you need to switch between various
geodetic systems (ntf and rgf93).
Bye,
Vincent.
Le jeudi 21 février 2013 à 18:28 +0100, Vincent Bain a écrit :
while discussing with S. Turek about r.in.wms coping with french
projection systems, I tested a dataset within grass70. Used to working
with grass64 I store the french nadgrid (ntf_r93.gsb)
in /usr/share/proj/ directory, making a symlink
here: /usr/lib/grass64/etc/nad/
On my local system I noticed for grass70 the grid is taken into account
if stored here:
/usr/local/grass-7.0.svn/etc/proj/nad/I am wondering :
- if these multiple locations for a single file are necessary;
- if they are correct for each version of grass I use;
- if it is worth adding the french grid to grids provided by default in
grass.Vincent.
