[GRASS-dev] Native GRASS support in VTK + Python and Java
Wow, yes, a lot on your plate there!
I did not realize that vtkGeo was still alive. Good to know.
Good luck with all this!
Ben
Soeren Gebbert wrote:
Hi Benjamin,
2009/8/28 Benjamin Ducke <benjamin.ducke@oxfordarch.co.uk
<mailto:benjamin.ducke@oxfordarch.co.uk>>
    This is great! Did you consider writing a little plug-on for one
    of the VTK viewers, like ParaView or VisIt, to allow direct access
    to GRASS data from there?
No.I do not consider to implement plug-ins for ParaView or Visit for now.
This may change in the far future.
First i need to validate the library concept and then i will implement
full raster,
vector, volume and grass sql database support .. and this will take a
while.
Then i need to understand the vtkGeo and projection concept in VTK 5.4+ .
So the plugin development does not have a high priority on my todo list. :slight_smile:
Soeren
    Ben
     > Hi,
     > JFYI i have implemented a small demo library which connects parts
    of the
     > grass gis library
     > with the Visual-Tool-Kit VTK.
     > It is called vtkGRASSBridge.
     > Additionally the VTK Python and Java wrapping mechanism have been
     > enabled. So the user can use the
     > library from C++, Python and Java.
     > Features:
     > * The library can read and write raster maps row by row, as well as
     > regions and the raster history.
     > * It can list files of the grass database.
     > * It can convert grass raster maps into the vtkImageData format
    and the
     > other way round.
     > Missing Features:
     > * Full raster support (categories, colors, ..)
     > * Imagery support (groups, ...)
     > * Full vector support ....
     > You can use every vtkDataSet processing algorithm available in
    VTK (more
     > than 50 i think)
     > to process the converted raster map and write it back to the grass
     > raster database.
     > You can use the VTK render functionality to display the raster map.
     > There are examples and tests in the library showing this
    functionality
     > in Python.
     > The documentation of the library can be found here:
    http://www-pool.math.tu-berlin.de/~soeren/grass/files/vtkGRASSBridge/doc/html/index.html
    <http://www-pool.math.tu-berlin.de/~soeren/grass/files/vtkGRASSBridge/doc/html/index.html&gt;
     > The GPL source code is located here:
     http://www-pool.math.tu-berlin.de/~soeren/grass/files/vtkGRASSBridge/vtkGRASSBridge_0.1.tar.gz
    <http://www-pool.math.tu-berlin.de/~soeren/grass/files/vtkGRASSBridge/vtkGRASSBridge_0.1.tar.gz&gt;
     > Here is a small Python code example to read and write grass
    raster maps
     > in Python (within a grass session):
     > #include the VTK and vtkGRASSBridge Python libraries
     > from libvtkCommonPython import *
     > from libvtkFilteringPython import *
     > from libvtkGraphicsPython import *
     > from libvtkRenderingPython import *
     > from libvtkIOPython import *
     > from libvtkImagingPython import *
     > from libvtkGRASSBridgeIOPython import *
     > from libvtkGRASSBridgeCommonPython import *
     > #Initiate grass
     > init = vtkGRASSInit()
     > #The region settings
     > region = vtkGRASSRegion()
     > region.ReadCurrentRegion()
     > region.SetCols(10)
     > region.SetRows(10)
     > region.AdjustRegion()
     > #Create a new map and write some data into it
     > writer = vtkGRASSRasterMapWriter()
     > writer.SetMapTypeToCELL()
     > writer.SetRegion(region)
     > writer.UseUserDefinedRegion()
     > writer.OpenMap("test_cell")
     > #this is the row buffer
     > data = vtkIntArray()
     > data.SetNumberOfTuples(writer.GetNumberOfCols())
     > #iterate over each raster cell
     > for i in range(writer.GetNumberOfRows()):
     > for j in range(writer.GetNumberOfCols()):
     > data.SetTuple1(j, i + j + 100)
     > writer.PutNextRow(data)
     > #close the map
     > writer.CloseMap()
     > #now reopen the map for reading
     > reader = vtkGRASSRasterMapReader()
     > reader.OpenMap("test_cell")
     > #print the cells to stdout
     > print " "
     > for i in range(reader.GetNumberOfRows()):
     > data = reader.GetRow(i)
     > for j in range(reader.GetNumberOfCols()):
     > print data.GetTuple1(j),
     > print " "
     > #print the range of the raster map
     > val = [0,0]
     > reader.GetRange(val);
     > print "Range ", val
     > #print the history
     > print reader.GetHistory()
     > reader.CloseMap()
     > Have fun
     > Soeren
     > grass-dev mailing list
     > grass-dev@lists.osgeo.org <mailto:grass-dev@lists.osgeo.org>
     > http://lists.osgeo.org/mailman/listinfo/grass-dev
    Benjamin Ducke
    Senior Applications Support and Development Officer
    Oxford Archaeological Unit Limited
    Janus House
    Osney Mead
    OX2 0ES
    Oxford, U.K.
    Tel: +44 (0)1865 263 800 (switchboard)
    Tel: +44 (0)1865 980 758 (direct)
    Fax :+44 (0)1865 793 496
    benjamin.ducke@oxfordarch.co.uk <mailto:benjamin.ducke@oxfordarch.co.uk>
    Files attached to this email may be in ISO 26300 format (OASIS Open
    Document Format). If you have difficulty opening them, please visit
    http://iso26300.info for more information.
Benjamin Ducke
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
