On Mon, September 3, 2007 17:38, Moritz Lennert wrote:
Benjamin wrote:
>> So, how are we going to go ahead?
Glynn answered:
> Figure out how to debug the processes. If you can't get gdb to work, I
> can only suggest logging every significant event at the lowest level,
> i.e. log every read/write operation: the arguments, the return code,
> and the complete data (i.e. the buffer contents before read and after
> write). This is all done in the RPC/XDR library, in xdr_stdio.c. It
> will probably help to also log the beginning/end of each procedure
> call (i.e. lib/db/dbmi_base/xdrprocedure.c).
I would really like this to be solved, so I am willing to try to find
some time to do the logging effort. Benjamin, have you advanced on this ?
I will need some time understanding the xdr logic and code, but hope to
be able to help with this.
Ok, very first simple debugging effort seems to confirm timin issue.
Here's what I did:
diff -u dbmi_base dbmi_base_debug/
Common subdirectories: dbmi_base/CVS and dbmi_base_debug/CVS
Only in dbmi_base_debug/: OBJ.i686-pc-mingw32
diff -u dbmi_base/xdrint.c dbmi_base_debug/xdrint.c
--- dbmi_base/xdrint.c Thu Oct 5 06:13:28 2006
+++ dbmi_base_debug/xdrint.c Mon Sep 3 20:17:35 2007
@@ -10,10 +10,12 @@
stat = DB_OK;
+ G_debug(1, "xdrint.c: Begin send");
xdr_begin_send (&xdrs);
if(!xdr_int (&xdrs, &n))
stat = DB_PROTOCOL_ERR;
xdr_end_send (&xdrs);
+ G_debug(1, "xdrint.c: End send");
if (stat == DB_PROTOCOL_ERR)
db_protocol_error();
diff -u dbmi_base/xdrprocedure.c dbmi_base_debug/xdrprocedure.c
--- dbmi_base/xdrprocedure.c Thu Oct 5 06:13:28 2006
+++ dbmi_base_debug/xdrprocedure.c Mon Sep 3 20:17:35 2007
@@ -40,10 +40,12 @@
stat = DB_OK;
+ G_debug(1, "xdrprocedure.c: Begin receive");
xdr_begin_recv (&xdrs);
if(!xdr_int (&xdrs, n))
stat = DB_EOF;
xdr_end_recv (&xdrs);
+ G_debug(1, "xdrprocedure.c: End receive");
return stat;
and now, after setting 'g.gisenv set=DEBUG=1', I cannot reproduce the
deadlock anymore, using Benjamin's test data, except when I do other
things on the machine (open other windows, type an email, etc). When I
just run the command and stare at the screen I get no deadlock. With
DEBUG=0 I get the same irregular deadlock.
I'll dig into xdrstdio.c now.
Moritz
