[GRASS-dev] Network Analysis
I think this should go at least into 6.5.svn for now.
We should also think about including Daniel's contribution
in 6.4.1.
It seems misplaced in the add-ons repository as it
covers some core functionality (and would go nicely
with the other v.net.* modules already in base).
If there are no major concerns, I will integrate the
code into 6.5 svn. But I don't know enough about
the changes in the vector architecture for GRASS 7,
so someone else would need to sync with that branch
(or provide me with some information about the most
important things to keep in mind when porting vector
code to version 7).
In any case, Daniel, can you please put an entry with
a description on the add-ons Wiki page? Right now it
is hard to find your code.
Ben
Daniel Bundala wrote:
Hello everyone,
during the past few months I worked on a Google Summer of Code project
to extend GRASS network functionality. I sent a final summary report
to OSGeo GSoC mailing list. Since there are people not subscribed to
that mailing list who might be interested in the project, I was asked
to sent the report to this list and stress the paragraph on inclusion
into the main GRASS....
The goal of my project, which I have successfully accomplished, was to
implement modules for network analysis. This includes basic methods
such as: strongly and weakly connected components, minimum spanning
trees, bridges and articulation points as well as more complicated and
advanced tools for calculating maximum flow, minimum cut or
k-connectivity in a network. There is also a bunch of modules finding
shortest paths in a network. One module computes all-pairs shortest
paths, another finds the shortest paths between nodes and a given set
of features and, finally, there is a module that finds fastest paths
using timetables.
All module follow standard GRASS conventions. This holds both for the
code and user interface. I also tried to make the modules as flexible
as possible -- each of them accepts a wide range of parameters, which
can alter the behaviour. Moreover, the algorithms are separated from
the modules and stored in a library. An effect of this is that the
modules are mostly straightforward (only exception is v.net.timetable)
and consist only of reading the input, calling a few library functions
and writing an appropriate output. Another advantage of this approach
is that the “core functionality” can be reused in other modules. Much
more about the modules (a lot of pictures and link to code) can be
found at mi wiki: http://grass.osgeo.org/wiki/GSoC_Network_Analysis.
I have learnt a lot about GRASS and its vector architecture however
this was my second summer working on vector modules. This was the
first time I really had to work with attributes data and so I have
learnt a lot about the data management. At the beginning, I found the
system with many layers and multiple categories a bit complicated but
in the process of developing the modules I have discovered its
expressiveness and enormous power.
At the moment, my code is stored in add-ons repository. I already know
about several people using the modules for their work and I hope that
the modules will eventually be integrated into the main distribution
and bring eternal joy to all GRASS users.
Finally, I want to thank my mentor (Wolf Bergenheim), OSGEO project
coordinator (Wolf Bergenheim) and the whole GRASS, OSGeo and Google
Summer of Code community for support, T-shirts and for doing a
wonderful job! Thanks!
Daniel
grass-dev mailing list
grass-dev@lists.osgeo.org
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeological Unit Limited
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
benjamin.ducke@oxfordarch.co.uk
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
2009/9/4 Benjamin Ducke <benjamin.ducke@oxfordarch.co.uk>:
in 6.4.1.
agreed with 6.5/7.0, I can't see any point why to include it to 6.4.1.
GRASS 6.4.1 will be bugfixes release, such release should not
introduce any new features.
Not really, GRASS Addons is used for Goggle SoC by default. After some
time results of such projects can be merged into main GRASS
repository. I suspect to see Daniel's work in trunk till the end of
the year.
I would vote to postpone the integration to October (let's say). At
least there should be a plan for that. In the case of Goggle SoC
project the integration should be done by mentor after discussion with
the student (in case of v.krige, the integration is planned for
November).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
