[GRASS-dev] network analysis
Is there any module to do network analysis on gui.
when running v.net.path from grass shell open default menuform as for other modules.
does wxgui not have such a module to do network analysis graphically.
Rashad
2010/6/16 Mohammed Rashad <rashadkm@yahoo.com>:
modules.
no, it would be cool to have at least implementation of d.path for wx
displays (e.g. based on v.net.path and temp vector output), volunteers
welcomed.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Mohammed Rashad:
> graphically.
Martin:
d.path for wx displays (e.g. based on v.net.path and temp vector
output), volunteers welcomed.
d.path in non-interactive mode should have everything you need
already, see the wrapper script used in the tcl/tk GUI. e.g.
AFAIK this works on WinGrass.
Hamish
Hamish:
sorry, wrong, but d.path in non-interactive mode if fed a starting/ending
point and vector map should render a map ready for combining.
the gis.m wrapper script sets up a backdrop map, which isn't needed.
Hamish
