[GRASS-dev] new addon: i.cutlines - Creates semantically meaningful tile borders
Hi to all,
A new addon is available [1]: i.cutlines tiles the images into tiles with irregular borders that avoid cutting through meaningful objects. This allows tiling an image for parallel processing while avoiding border effects.
Enjoy !
Moritz
[1] https://grass.osgeo.org/grass74/manuals/addons/i.cutlines.html
On Tue, Mar 13, 2018 at 4:06 PM, Moritz Lennert
<mlennert@club.worldonline.be> wrote:
Hi to all,
Enjoy !
Cool!
It would also be interesting for post-orthophoto mosaiking.
Hi Moritz, all,
Hi to all,
we are currently trying to use this approach on a huge (?) area of 50
gigapixels of aerial images (i.e., the free openNRW 10cm orthophotos)
which we have to classify.
In future the areas we'll have to process may be even bigger. Right
now, as far as I understand, i.cutlines is reading the entire images.
This becomes increasingly difficult with bigger areas due to hardware
limitations.
Do you have a suggestion how to deal with that? Kind of chicken and
egg problem? :slight_smile:
thanks
Hi Markus,
On 13/08/18 13:41, Markus Neteler wrote:
Hi Moritz, all,
Hi to all,
limitations.
AFAIK, the only moment where i.cutlines potentially reads the whole image would be in the edge detection part. That's why there is the tiling option to avoid just that. So, unless I'm forgetting something, you should be able to work on large images. If you have seen this crash the module, please file a bug report.
Note that for versions < 7.5 (I'll have to check whether Pietro's fix was backported to 7.4) there is a parameter name conflict between i.zc and the GridModule class used for the tiling, so you'd have to use i.edge.
Moritz
Hi Moritz,
On Mon, Aug 13, 2018 at 2:04 PM, Moritz Lennert
to avoid just that.
I suppose you refer to
tile_width=integer
   Width of tiles for tiled edge detection (pixels)
tile_height=integer
   Height of tiles for tiled edge detection (pixels)
a bug report.
OK, fine, we'll try and report.
backported to 7.4)
I'm not sure either.
At time we use trunk.
thanks,
On 13/08/18 15:30, Markus Neteler wrote:
Hi Moritz,
to avoid just that.
tile_width=integer
tile_height=integer
a bug report.
backported to 7.4)
Actually you backported it: https://trac.osgeo.org/grass/changeset/72541/grass/branches/releasebranch_7_4/lib/python/pygrass
So, yes, it should work with 7.4.1.
Moritz
Hi Moritz,
to avoid just that.
tile_width=integer
tile_height=integer
a bug report.
A colleague working with a large dataset > 10e9 pixels) just reported that the module does not crash, but that it seems to take "forever" (he stopped the process after a day). I guess this is in the r.cost phase.
An option would be to tile (and parallelize) the entire process which would mean finding cutlines in the individual tiles, making sure that the start and endpoints of these cutlines match the start and endpoints on the neighboring tiles...
Any suggestions are welcome.
Moritz
Hi Moritz,
to avoid just that.
tile_width=integer
tile_height=integer
a bug report.
I see this in r.cost's main.c:
420 /* this is most probably the limitation of r.cost for large datasets
421 * segment size needs to be reduced to avoid unecessary disk IO
422 * but it doesn't make sense to go down to 1
423 * so use 64 segment rows and cols for <= 200 million cells
424 * for larger regions, 32 segment rows and cols
425 * maybe go down to 16 for > 500 million cells ? */
So maybe it's time to experiment a bit more with r.cost in very large regions ?
Moritz
