[GRASS-dev] new addon module: i.superpixels.slic - image segmentation using the SLIC segmentation method
Dear all,
Thanks to initial work by Rashad, extensively completed by Markus Metz,
we now have a new addon module which allows to segment images into
so-called superpixels, using the SLIC algorithm as proposed by Achanta
et al [1].
The module uses a spatially constrained kmeans algorithm to group
neighboring pixels into larger ensemble, the "superpixels". These
superpixels can be used as a specific form of segmentation by itself,
or they can be used as seed input to i.segment's region-growing
algorithm.
Thank you very much to the two authors for the great work !
Moritz
[1] http://ivrl.epfl.ch/research/superpixels
Congratulations to the authors of i.superpixels.slic to a great achievement! I’ve noticed lot of promising commits.
I’ve a suggestion to rename the one of the option called k. I think we were recently changing a lot of options in modules from a letter to a more descriptive name (num, number, pixels, num_pixels, …?).
k=integer
Number of super pixels
Default: 200
I’ve also added an example, so please review or add. (I suppose combination with i.segment can be included in another example.)
Vaclav
On Tue, Jan 31, 2017 at 1:19 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Dear all,
et al [1].
neighboring pixels into larger ensemble, the “superpixels”. These
or they can be used as seed input to i.segment’s region-growing
algorithm.
Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
achievement! I've noticed lot of promising commits.
I've a suggestion to rename the one of the option called `k`. I think we
more descriptive name (num, number, pixels, num_pixels, ...?).
+1
I've also added an example, so please review or add.
Perfect, thanks a lot !
(I suppose
Yes.
Plus potentially an example with i.superpixels.slic + i.segment.stats + v.class.mlR.
I think it is also time to write a more extensive wiki page on OBIA in GRASS... :slight_smile:
Moritz
+1
Done. I chose num_pixels.
Moritz
