Hi everybody,
I have very slowly started to develop a toolset to search, download and import Landsat data based on landsatxplore python library [0]. I went for landsatxplore library because among the other options, it was the most active in terms of development, i.e., commits in the repo. Currently, I’m working in my repo [1], but hopefully, once it’s done and reviewed by you, it can be moved to addons.
The toolset attempts to be similar to i.modis and i.sentinel, but it is pretty raw right now. I have started with i.landsat.download and the basic functionality is there (details in the html). I recycled and adapted parts of i.sentinel.download to read the settings file and get the region extent. Next step is to draft i.landsat.import. Then, I’ll be working on writing (a bit) better code. Is it recommended to create classes?
Since I’m not a programmer, this is quite a challenge for me, hence I appreciate your patience, help and suggestions, either by this means or in the repo itself.
Thanks much in advance!
Vero
[0] https://github.com/yannforget/landsatxplore
[1] https://github.com/veroandreo/i.landsat
