FYI I just submitted my (first!) GRASS add-on, called v.what.rast.multi 0.
It is a super simple Python wrapper around v.what.rast, and allows to query a suite of rasters in one go:
v.what.rast.multi map=mygeodetic_pts raster=elev_state_500m,slope,aspect columns=elevation,slope,aspect
Pierre
I guess I probably should have added the URL: https://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.what.rast.multi
Apologies!
On 8 May 2017 at 17:16, Pierre Roudier <pierre.roudier@gmail.com> wrote:
Pierre
On 08/05/17 07:16, Pierre Roudier wrote:
FYI I just submitted my (first!) GRASS add-on, called v.what.rast.multi [0].
Very useful, thanks !
Don't forget to add the addon to the Makefile in the grass-addons/grass7/vector directory.
Moritz
Done – thanks for the heads-up Moritz!
Don’t forget to add the addon to the Makefile in the grass-addons/grass7/vector directory.
Moritz
Very Nice!!
I have one question: Because it is called v.what.rast.multi and not r.what.rast.multi?
Best
2017-05-08 18:25 GMT-03:00 Pierre Roudier <pierre.roudier@gmail.com>:
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Moritz
Pablo J. Zader
Universidad Nacional de Córdoba
GIS and remote sensing developer
Lic. en Cs. de la Computación
Mgtr. en Aplicaciones Espaciales de Alerta y Respuesta Temprana a Emergencias
pablo.zader@gmail.com
"Los Grandes Hombres hablan sobre ideas…
Los Hombres Promedio hablan sobre cosas…
Los Hombres Pequeños hablan… de otros Hombres.
del libro Matemática estas ahi? A. Paenza "
On 8 May 2017 at 07:16, Pierre Roudier <pierre.roudier@gmail.com> wrote:
thanks, it is useful
to improve a little bit, you add multiprocessing to the module, for
example a process for each raster
Pierre
ciao
Luca
www.lucadelu.org
On 09/05/17 07:26, pablo zader wrote:
Very Nice!!
r.what.rast.multi?
It is a frontend to v.what.rast which loads information from a raster map into the attribute table of a point vector map. As it is the vector map which is modified, it is considered a vector module.
Moritz
Hi Pierre,
I have one question about the code. In lines 126-130 you create an object 'fl', which you subsequently do not seem to use. Perhaps in line 150 it should be flags=fl ?
Something else, last year I wrote an addon r.what.rastlabel (https://github.com/ecodiv/GRASS-scripts/tree/master/v.what.rastlabel) which can be used to (multiple) raster values and labels. Optionally, it can also upload raster values only, like your addon (that part uses the same approach you use). I have not yet added it to the grass addon repository. I might do that later, at which point we can also see if it makes sense to merge the two.
Paulo
Interesting, could help to speed up with large point data layers.
Pierre
Hello Pierre,
Thanks for this new add-on! Comes on time for me
I’m testing it and I have observed something odd.
I’m querying integer maps but v.what.rast.multi gives me float values. I run v.what.rast and I get the proper integer values. Does it have anything to do with what Paulo just pointed out?
Thanks much!
Vero
2017-05-09 9:30 GMT+02:00 Paulo van Breugel <p.vanbreugel@gmail.com>:
Hi Pierre,
I have one question about the code. In lines 126-130 you create an object ‘fl’, which you subsequently do not seem to use. Perhaps in line 150 it should be flags=fl ?
Paulo
Pierre
On 09/05/17 14:37, Veronica Andreo wrote:
Hello Pierre,
I'm testing it and I have observed something odd.
I'm querying integer maps but v.what.rast.multi gives me float values. I
The module just loops over a series of v.what.rast calls, so results should not be different. If any, Paulo's point reinforces this as the '-i' flag (i.e.interpolate nearest points) is never used...
And I cannot confirm:
g.region rast=elev_ned_30m
v.random test npoints=500
r.mapcalc "srtm = int(elev_srtm_30m)"
r.mapcalc "ned = int(elev_ned_30m)"
v.what.rast.multi map=test raster=elev_srtm_30m,elev_ned_30m,srtm,ned columns=srtm_float,ned_float,srtm_int,ned_int
v.db.select test col=srtm_float,ned_float,srtm_int,ned_int
105.1695|103.4447|104|102
124.6583|122.6958|124|122
104.6636|93.28199|104|93
81.77528|79.49014|81|78
90.53698|86.29738|89|85
80.44241|76.85014|79|76
127.8045|125.4002|127|124
106.0921|104.8796|105|104
151.5683|148.3245|150|148
121.2332|116.3521|120|116
123.2887|115.1104|123|114
Moritz
Hello Pierre,
Sorry, I take that back: the -i flag is always set as what is passed on to v.what.rast is 'flags' and without the '-i' flag set still is non-null (it contains "{'i': False}") and so
'if (interp_flag->answer)'
in v.what.rast/main.c returns true.
So, yes the issue is linked to Paulo's remark.
Moritz
Hello Pierre,
Fixed in r71072.
But
v.what.rast.multi map=test raster=elev_srtm_30m,elev_ned_30m,srtm,ned columns=srtm_float_nofl,ned_float_nofl,srtm_int_nofl,ned_int_nofl
v.what.rast.multi -i map=test raster=elev_srtm_30m,elev_ned_30m,srtm,ned columns=srtm_float_fl,ned_float_fl,srtm_int_fl,ned_int_fl
cat|srtm_float_nofl|ned_float_nofl|srtm_int_nofl|ned_int_nofl|srtm_float_fl|ned_float_fl|srtm_int_fl|ned_int_fl
1|88.40672|84.94218|88|84|88.74082|85.08109|88|84
2|109.1437|98.23732|109|98|108.8838|98.40421|108|98
3|121.3047|117.567|121|117|121.5324|117.8318|121|117
4|142.1468|131.73|142|131|142.0981|131.7365|141|131
5|121.9686|122.3212|121|122|122.9578|123.2583|122|122
6|80.502|82.1487|80|82|81.29526|82.14999|80|81
So, integer remains integer...
Moritz
Now it works! Thanks a lot for such a quick fix
best,
Vero
2017-05-09 15:25 GMT+02:00 Moritz Lennert <mlennert@club.worldonline.be>:
Hello Pierre,
should not be different. If any, Paulo’s point reinforces this as the
‘-i’ flag (i.e.interpolate nearest points) is never used…
to v.what.rast is ‘flags’ and without the ‘-i’ flag set still is
non-null (it contains “{‘i’: False}”) and so
‘if (interp_flag->answer)’
So, yes the issue is linked to Paulo’s remark.
Fixed in r71072.
But
So, integer remains integer…
Moritz
Thanks Luca, that would be a good idea indeed!
Any pointers to implement this? I’m unfamiliar with parallel processing in Pygrass.
P
Pierre
ciao
Luca
www.lucadelu.org
Hi Paulo,
fl is used to store flags passed to the command.
There was a typo in my code, and Moritz was kind enough to commit a corrected version of the add-on (thanks Moritz!),
Would be more than happy to merge both addons, they do look similar enough to be merged.
P
On 9 May 2017 at 19:30, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Hi Pierre,
Paulo
Pierre
Any pointers to implement this? I'm unfamiliar with parallel processing
in Pygrass.
You can look at i.pansharpen for a simple example:
https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_2/scripts/i.pansharpen/i.pansharpen.py#L151
or for a bit more sophisticated handling using PyGRASS:
https://grass.osgeo.org/grass72/manuals/libpython/pygrass.modules.interface.html#pygrass.modules.interface.module.ParallelModuleQueue
Other examples exist (cf i.segment.uspo for example)
Moritz
