Hello everybody.
I am writing to the grass-dev list because I am having difficulty to upload a new add-on called r.forcircuar to the Grass addon repository. The add-on is called r.forcircular, it was developed by University of Florence inside a research project aiming to the circular bioeconomy and sustainability of the forest supply chain. I followed the procedure shown at this link https://github.com/OSGeo/grass/blob/main/CONTRIBUTING.md , but every time I try to push I get an error message related to incorrect access privileges. My github account is fra-lab.
Thank you very much for helping.
Francesco
Hi Francesco,
On Tue, Feb 1, 2022 at 9:53 AM Francesco Geri <francescogeri@tim.it> wrote:
Hello everybody.
Great!
The idea is that you open a pull request so that it can be easily
reviewed. Upon approval it will then be merged.
If the CONTRIBUTING.md file isn't clear in this regard, please let us
know which line(s) should be improved. A great occasion to make it
better!
Francesco
Best,
Thank you very much Markus
better!
in fact, I have difficulty in the very initial stages of set-up. When I try to follow the line to fork the repository:
*git clone git@github.com:your_GH_account/grass.gi*t
and so
git clone git@github.com:fra-lab/grass.git
I obtain this error message:
Clone in ‘grass’ in corso…
The authenticity of host ‘github.com (140.82.121.3)’ can’t be established.
ECDSA key fingerprint is SHA256:p2QAMXNIC1TJYWeIOttrVc98/R1BUFWu3/LiyKgUfQM.
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
Warning: Permanently added ‘github.com,140.82.121.3’ (ECDSA) to the list of known hosts.
git@github.com: Permission denied (publickey).
fatal: Impossibile leggere dal repository remoto.
Assicurati di disporre dei privilegi d’accesso corretti
e che il repository esista.
In english:
fatal: Unable to read from remote repository.
Make sure you have the correct access privileges
and that the repository exists.
út 1. 2. 2022 v 12:40 odesílatel Francesco Geri <francescogeri@tim.it> napsal:
In english:
Did you fork the repository before trying to clone it? I cannot see your fork in the list of forks and also not on your profile when stalking it.
You can do it interactively at the website by going to [1] or [2] (depending on whether you want to fork GRASS itself, or the addons repository) and clicking on “Fork” in the upper right corner. If you didn’t do that, then the repository fra-lab/grass does not exist and therefore couldn’t be cloned.
[1] https://github.com/OSGeo/grass
[2] https://github.com/OSGeo/grass-addons
Hi Francesco,
And welcome!
Just a little heads up: The right place to add a new module is the grass-addons repository (you seem to try to add it to the GRASS GIS core):
grass-addons/CONTRIBUTING.md at grass8 · OSGeo/grass-addons (github.com)
Please note that there are also some formal, “legal boxes” to tick:
The submission must be compliant with the GRASS submission rules as found in the GRASS source code and RFC2 (Legal aspects of submission):
https://trac.osgeo.org/grass/wiki/RFC
If I remember correctly, you have to confirm towards the Project Steering Committee (PSC) that RFC 2 is read and understood and that your contributions adhere to the requirements outlined there…
Others, please correct me if that only applies to write access to the repo…
Looking forward to seeing your addon in the repository!
Stefan
From: grass-dev grass-dev-bounces@lists.osgeo.org On Behalf Of Ondrej Pešek
Sent: tirsdag 1. februar 2022 12:41
To: Francesco Geri francescogeri@tim.it
Cc: GRASS developers list grass-dev@lists.osgeo.org
Subject: Re: [GRASS-dev] new addon
In english:
Thank you very much.
Cloning my fork everything gone ok.
I created a new branch called “r.forcircular”, add the new folder and then commit/push. Then I did the pull request at the website.
I hope I did everything right this time.
Thanks again.
In english:
