I finally got the Coverity Scan compilation running again. It offers
static compilation to catch code errors like dead code, unreachable
conditions and more.
After some time of struggling with the compilation I understood that
_Float128 was undefined. The trick: "cov-build" is still based on gcc6
while my system is more recent.
Hence, _Float128 has to be defined in an extra include file and given
to "cov-build" via CFLAGS:
CFLAGS="... -include /tmp/coverity.h ..."
For the latest Coverity Scan report, see below.
---------- Forwarded message ---------
Date: Mon, Apr 1, 2019 at 3:53 PM
Subject: New Defects reported by Coverity Scan for grass
To: <neteler@gmail.com>
Please find the latest report on new defect(s) introduced to grass
found with Coverity Scan.
1 new defect(s) introduced to grass found with Coverity Scan.
1584 defect(s), reported by Coverity Scan earlier, were marked fixed
in the recent build analyzed by Coverity Scan.
New defect(s) Reported-by: Coverity Scan
Showing 1 of 1 defect(s)
** CID 1400466: (UNINIT)
/misc/m.nviz.image/surface.c: 127 in load_rasters()
/misc/m.nviz.image/surface.c: 143 in load_rasters()
/misc/m.nviz.image/surface.c: 150 in load_rasters()
/misc/m.nviz.image/surface.c: 164 in load_rasters()
/misc/m.nviz.image/surface.c: 178 in load_rasters()
________________________________________________________________________________________________________
*** CID 1400466: (UNINIT)
121 color_const->answers[i -
122
ncolor_map]),
123 data);
124 }
125 else { /* use by default elevation
map for coloring */
126 if (nelev_map > 0) {
Using uninitialized value "mapset" when calling "G_fully_qualified_name".
127 Nviz_set_attr(id, MAP_OBJ_SURF, ATT_COLOR, MAP_ATT,
128 G_fully_qualified_name(params->elev_map->
129
answers[i], mapset),
130 -1.0, data);
131 G_verbose_message(_("Color attribute not
defined, using default <%s>"),
132 G_fully_qualified_name(params->
137 G_fatal_error(_("Missing color attribute for
surface %d"),
138 i + 1);
139 }
140 }
141 /* mask */
142 if (i < nmask_map && strcmp(params->mask_map->answers[i], "")) {
143 Nviz_set_attr(id, MAP_OBJ_SURF, ATT_MASK, MAP_ATT,
144
G_fully_qualified_name(params->mask_map->answers[i],
145 mapset), -1.0, data);
146 }
147
148 /* transparency */
144
146 }
147
149 if (i < ntransp_map &&
strcmp(params->transp_map->answers[i], "")) {
150 Nviz_set_attr(id, MAP_OBJ_SURF, ATT_TRANSP, MAP_ATT,
151 G_fully_qualified_name(params->
152 transp_map->answers[i],
153 mapset), -1.0, data);
154 }
155 else if (i - ntransp_map < ntransp_const &&
158 atof(params->transp_const->
159 answers[i - ntransp_map]), data);
160 }
161
162 /* shininess */
163 if (i < nshine_map &&
strcmp(params->shine_map->answers[i], "")) {
164 Nviz_set_attr(id, MAP_OBJ_SURF, ATT_SHINE, MAP_ATT,
165 G_fully_qualified_name(params->
166 shine_map->answers[i],
167 mapset), -1.0, data);
168 }
169 else if (i - nshine_map < nshine_const &&
172 atof(params->shine_const->answers[i
- nshine_map]),
173 data);
174 }
175
176 /* emission */
177 if (i < nemit_map && strcmp(params->emit_map->answers[i], "")) {
178 Nviz_set_attr(id, MAP_OBJ_SURF, ATT_EMIT, MAP_ATT,
179
G_fully_qualified_name(params->emit_map->answers[i],
180 mapset), -1.0, data);
181 }
182 else if (i - nemit_map < nemit_const &&
183 strcmp(params->emit_const->answers[i -
nemit_map], "")) {
To view the defects in Coverity Scan visit,
https://u2389337.ct.sendgrid.net/wf/click?upn=08onrYu34A-2BWcWUl-2F-2BfV0V05UPxvVjWch-2Bd2MGckcRboWqkKU-2BRIvV-2FiDOYXTV0mKHmFWVx0lKOUGjtP4kEYbg-3D-3D_bOkZeOtpfWx9uhruxsjO9h13eZbGUt8w2PXepo9CPVnykYQUUzYUMdnMZ7ShYehoMP-2BPl-2BHB6CjtqKN7JoMW-2Bq1VJgum08fTcR7T8nOQ9VDxehSMEpon1SL3LN7oGnpB3cIHgasZDQ7XAQ6xQhaIBW4GE6BccpGpc0-2FkWyOvoTg4lrNJ-2BPFFt-2BauAzeueAKy1Iio18sqJK3-2F5W-2FsBHEbeg-3D-3D
To manage Coverity Scan email notifications for "neteler@gmail.com",
click https://u2389337.ct.sendgrid.net/wf/click?upn=08onrYu34A-2BWcWUl-2F-2BfV0V05UPxvVjWch-2Bd2MGckcRbVDbis712qZDP-2FA8y06Nq41ouTkv7a6ZwS4TYALxGrvo7qxH3UJFTiswOJgiUwLccdigSkh3uYLNHlFfY7iFv5uN0cWFsArXwuActVXTzCBPbZg9MtKBV2zgb3YYzpy1E-3D_bOkZeOtpfWx9uhruxsjO9h13eZbGUt8w2PXepo9CPVnykYQUUzYUMdnMZ7ShYehoYLOMg8luJSAwLK1yMEEheNREf66-2BbZBwgkG5JhDIesc0W28CdQLx4stqyg0fFo7P8kGZ-2B16w35Fbux8PAtYtM0FJFl08-2FZHvNdFJiiR5JlikKMU-2BEmIiyx-2BdearkQrBqXmzT2LSmsgwOd7EuqCGjag-3D-3D
