[GRASS-dev] New Defects reported by Coverity Scan for grass
FYI, a scan of r64128 done today:
---------- Forwarded message ----------
Date: Tue, Jan 13, 2015 at 3:39 PM
Subject: New Defects reported by Coverity Scan for grass
Please find the latest report on new defect(s) introduced to grass
found with Coverity Scan.
22 new defect(s) introduced to grass found with Coverity Scan.
32 defect(s), reported by Coverity Scan earlier, were marked fixed in
the recent build analyzed by Coverity Scan.
New defect(s) Reported-by: Coverity Scan
Showing 20 of 22 defect(s)
** CID 1262578: Explicit null dereferenced (FORWARD_NULL)
/lib/gis/ls.c: 118 in G_ls2()
** CID 1262577: Improper use of negative value (NEGATIVE_RETURNS)
** CID 1262576: Improper use of negative value (NEGATIVE_RETURNS)
** CID 1262575: Improper use of negative value (NEGATIVE_RETURNS)
/lib/vector/Vlib/write_nat.c: 205 in V2_rewrite_line_nat()
** CID 1262574: Resource leak (RESOURCE_LEAK)
/lib/driver/text3.c: 152 in convert_str()
** CID 1262573: Resource leak (RESOURCE_LEAK)
/lib/gis/ls.c: 121 in G_ls2()
** CID 1262572: Resource leak (RESOURCE_LEAK)
/misc/m.nviz.image/vector.c: 86 in load_vectors()
** CID 1262571: Resource leak (RESOURCE_LEAK)
/lib/vector/Vlib/snap.c: 571 in Vect_snap_lines_list_rtree()
** CID 1262570: Resource leak (RESOURCE_LEAK)
/lib/arraystats/class.c: 245 in AS_class_equiprob()
** CID 1262569: Resource leak (RESOURCE_LEAK)
/lib/vector/Vlib/snap.c: 889 in Vect_snap_lines_list_rtree()
** CID 1262568: Resource leak (RESOURCE_LEAK)
/lib/vector/Vlib/snap.c: 527 in Vect_snap_lines_list_kdtree()
** CID 1262567: Resource leak (RESOURCE_LEAK)
/misc/m.nviz.image/volume.c: 46 in load_rasters3d()
** CID 1262565: Copy into fixed size buffer (STRING_OVERFLOW)
/display/d.mon/start.c: 60 in start()
/display/d.mon/start.c: 64 in start()
** CID 1262566: Resource leak (RESOURCE_LEAK)
/misc/m.nviz.image/surface.c: 54 in load_rasters()
** CID 1262564: Resource leak (RESOURCE_LEAK)
/lib/vector/Vlib/ascii.c: 475 in Vect_write_ascii()
** CID 1262563: Unbounded source buffer (STRING_SIZE)
/lib/gis/put_window.c: 48 in G_put_window()
** CID 1262562: Copy into fixed size buffer (STRING_OVERFLOW)
/display/d.vect.thematic/main.c: 189 in main()
** CID 1262561: Unbounded source buffer (STRING_SIZE)
/lib/gis/get_window.c: 65 in G_get_window()
** CID 1262560: Unused value (UNUSED_VALUE)
/lib/vector/Vlib/snap.c: 594 in Vect_snap_lines_list_rtree()
** CID 1262559: Unused value (UNUSED_VALUE)
/lib/vector/Vlib/snap.c: 235 in Vect_snap_lines_list_kdtree()
________________________________________________________________________________________________________
*** CID 1262578: Explicit null dereferenced (FORWARD_NULL)
112 dir_listing = (char **)G_realloc(dir_listing, (1 + n)
* sizeof(char *));
113 dir_listing[n] = G_store(dp->d_name);
114 n++;
115 }
116
117 /* Sort list of filenames alphabetically */
    Passing null pointer "dir_listing" to "qsort", which dereferences it.
118 qsort(dir_listing, n, sizeof(char *), cmp_names);
119
120 *num_files = n;
121 return dir_listing;
122 }
123
*** CID 1262577: Improper use of negative value (NEGATIVE_RETURNS)
/lib/vector/Vlib/write_nat.c: 46 in V1_write_line_nat()
40 \return feature offset into file
41 \return -1 on error
42 */
43 off_t V1_write_line_nat(struct Map_info *Map, int type,
44 const struct line_pnts *points, const
struct line_cats *cats)
45 {
    A negative constant "-1L" is passed as an argument to a parameter that cannot be negative.
46 return V1__write_line_nat(Map, -1, type, points, cats);
47 }
48
49 /*!
50 \brief Writes feature to 'coor' file at topological level
(internal use only)
51
*** CID 1262576: Improper use of negative value (NEGATIVE_RETURNS)
/lib/vector/Vlib/write_nat.c: 133 in V1_rewrite_line_nat()
127 }
128 else {
129 /* differ -> delete the old and append new */
130 /* delete old */
131 V1_delete_line_nat(Map, offset);
132
133 return V1__write_line_nat(Map, -1, type, points, cats);
134 }
135 }
136
137 /*!
138 \brief Rewrites feature to 'coor' file at topological level
(internal use only)
*** CID 1262575: Improper use of negative value (NEGATIVE_RETURNS)
199 offset = old_offset;
200 }
201 else {
202 /* differ -> delete the old and append new */
203 /* delete old */
204 V1_delete_line_nat(Map, old_offset);
    Assigning: "offset" = a negative value.
205 offset = -1;
206 }
207
208 /* delete feature from topology */
209 if (0 != V2__delete_line_from_topo_nat(Map, line, type,
old_points, old_cats))
210 return -1;
*** CID 1262574: Resource leak (RESOURCE_LEAK)
146
147 i = res;
148 cd = iconv_open("UCS-2BE", from);
149 if (cd == (iconv_t) -1)
150 return -1;
151 if (iconv(cd, (char **)&p1, &len, (char **)&p2, &i) ==
(size_t) -1)
    Variable "cd" going out of scope leaks the storage it points to.
152 return -1;
153 iconv_close(cd);
154
155 res -= i;
156 }
157 #else
*** CID 1262573: Resource leak (RESOURCE_LEAK)
115 }
116
119
120 *num_files = n;
    Variable "dfd" going out of scope leaks the storage it points to.
122 }
123
124 /**
125 * \brief Prints a directory listing to a stream, in
prettified column format
126 *
*** CID 1262572: Resource leak (RESOURCE_LEAK)
80
81 for (i = 0; vect->answers[i]; i++) {
82 mapset = G_find_vector2(vect->answers[i], "");
83 if (mapset == NULL) {
84 G_fatal_error(_("Vector map <%s> not found"), vect->answers[i]);
85 }
    Failing to save or free storage allocated by "G_fully_qualified_name(vect->answers[i], mapset)" leaks it.
86 id = Nviz_new_map_obj(map_obj_type,
87 G_fully_qualified_name(vect->answers[i],
88 mapset), 0.0, data);
89
90 /* set position */
91 x = atof(position->answers[i * 3 + 0]);
*** CID 1262571: Resource leak (RESOURCE_LEAK)
565 List = Vect_new_list();
566 if (getenv("GRASS_VECTOR_LOWMEM")) {
567 char *filename = G_tempfile();
568
569 rtreefd = open(filename, O_RDWR | O_CREAT | O_EXCL, 0600);
570 remove(filename);
    Variable "filename" going out of scope leaks the storage it points to.
571 }
572 RTree = RTreeCreateTree(rtreefd, 0, 2);
573
574 thresh2 = thresh * thresh;
575
576 /* Go through all lines in vector, and add each point to
structure of points */
*** CID 1262570: Resource leak (RESOURCE_LEAK)
239 }
240
241 if (j < (*nbreaks)) {
242 G_warning(_("There are classbreaks outside the range
min-max. Number of "
243 "classes reduced to %i, but using
probabilities for %i classes."),
244 j + 1, *nbreaks + 1);
    Ignoring storage allocated by "G__realloc("lib/arraystats/class.c", 245, classbreaks, j * 8UL)" leaks it.
245 G_realloc(classbreaks, j * sizeof(double));
246 for (i = 0; i < j; i++)
247 classbreaks[i] = 0;
248 }
249
250 j = 0;
*** CID 1262569: Resource leak (RESOURCE_LEAK)
883 RTreeDestroyTree(RTree);
884 if (rtreefd >= 0)
885 close(rtreefd);
886
887 G_verbose_message(_("Snapped vertices: %d"), nsnapped);
888 G_verbose_message(_("New vertices: %d"), ncreated);
    Variable "List" going out of scope leaks the storage it points to.
889 }
890
891
892 /*!
893 \brief Snap lines in vector map to existing vertex in threshold.
894
*** CID 1262568: Resource leak (RESOURCE_LEAK)
521 G_free(Index);
522 G_free(New);
523 kdtree_destroy(KDTree);
524
525 G_verbose_message(_("Snapped vertices: %d"), nsnapped);
526 G_verbose_message(_("New vertices: %d"), ncreated);
527 }
528
529 static void
530 Vect_snap_lines_list_rtree(struct Map_info *Map, const struct
ilist *List_lines,
531 double thresh, struct Map_info *Err)
532 {
*** CID 1262567: Resource leak (RESOURCE_LEAK)
40 mapset = G_find_raster3d(params->volume->answers[i], "");
41 if (mapset == NULL) {
42 G_fatal_error(_("3d raster map <%s> not found"),
43 params->volume->answers[i]);
44 }
45
    Failing to save or free storage allocated by "G_fully_qualified_name(params->volume->answers[i], mapset)" leaks it.
46 id = Nviz_new_map_obj(MAP_OBJ_VOL,
47 G_fully_qualified_name(params->volume->
48 answers[i], mapset), 0.0,
49 data);
50
51 /* set position */
*** CID 1262565: Copy into fixed size buffer (STRING_OVERFLOW)
54 G_fatal_error(_("Unable to get current working directory"));
55 ptr = output_path + strlen(output_path) - 1;
56 if (*(ptr++) != HOST_DIRSEP) {
57 *(ptr++) = HOST_DIRSEP;
58 *(ptr) = '\0';
59 }
    You might overrun the 4096 byte fixed-size string "output_path" by copying "output_name" without checking the length.
60 strcat(output_path, output_name);
61 G_message(_("Output file: %s"), output_path);
62 }
63 else {
64 strcpy(output_path, output_name); /* already full path */
65 }
58 *(ptr) = '\0';
59 }
62 }
63 else {
65 }
66
67 env_name = NULL;
68 G_asprintf(&env_name, "MONITOR_%s_MAPFILE", G_store_upper(name));
69 G_setenv(env_name, output_path);
*** CID 1262566: Resource leak (RESOURCE_LEAK)
48 mapset = G_find_raster2(params->elev_map->answers[i], "");
49 if (mapset == NULL) {
50 G_fatal_error(_("Raster map <%s> not found"),
51 params->elev_map->answers[i]);
52 }
53
    Failing to save or free storage allocated by "G_fully_qualified_name(params->elev_map->answers[i], mapset)" leaks it.
54 id = Nviz_new_map_obj(MAP_OBJ_SURF,
55 G_fully_qualified_name(params->
56 elev_map->answers[i],
57 mapset), 0.0, data);
58 }
59 else {
*** CID 1262564: Resource leak (RESOURCE_LEAK)
469 col_name =
db_get_column_name(db_get_table_column(Table, j));
470 G_important_message("%s", col_name);
471 }
472 G_warning(_("Export cancelled"));
473 db_close_database(driver);
474 db_shutdown_driver(driver);
    Variable "Table" going out of scope leaks the storage it points to.
475 return -1;
476 }
477 }
478 i++;
479 }
480 columns[icol] = NULL;
*** CID 1262563: Unbounded source buffer (STRING_SIZE)
42 * \return -1 on error (no diagnostic message is printed)
43 *
44 * \sa G_get_window(), G_set_window(), python.core.use_temp_region()
45 */
46 int G_put_window(const struct Cell_head *window)
47 {
    Assigning: "wind" = "getenv". "wind" is now tainted.
48 char *wind = getenv("WIND_OVERRIDE");
49
50 return wind ? G_put_element_window(window, "windows", wind)
51 : G_put_element_window(window, "", "WIND");
52 }
53
*** CID 1262562: Copy into fixed size buffer (STRING_OVERFLOW)
183 verbose = TRUE;
184
185 G_get_set_window(&window);
186
187 /* Read map options */
188
    You might overrun the 128 byte fixed-size string "map_name" by copying "map_opt->answer" without checking the length.
189 strcpy(map_name, map_opt->answer);
190
191 /* open vector */
192 level = Vect_open_old(&Map, map_name, "");
193
194 if (level < 2)
*** CID 1262561: Unbounded source buffer (STRING_SIZE)
59 if (regvar) {
60 char **tokens = G_tokenize(regvar, ";");
61 G__read_Cell_head_array(tokens, &st->dbwindow, 0);
62 G_free_tokens(tokens);
63 }
64 else {
65 char *wind = getenv("WIND_OVERRIDE");
66 if (wind)
67 G_get_element_window(&st->dbwindow, "windows", wind, G_mapset());
68 else
69 G_get_element_window(&st->dbwindow, "", "WIND", G_mapset());
70 }
*** CID 1262560: Unused value (UNUSED_VALUE)
588 line = List_lines->value[line_idx];
589
590 G_debug(3, "line = %d", line);
591 if (!Vect_line_alive(Map, line))
592 continue;
593
    Value from "Vect_read_line(Map, Points, Cats, line)" is assigned to "ltype" here, but that stored value is not used before it is overwritten.
594 ltype = Vect_read_line(Map, Points, Cats, line);
595
596 for (v = 0; v < Points->n_points; v++) {
597 G_debug(3, " vertex v = %d", v);
598 nvertices++;
599
*** CID 1262559: Unused value (UNUSED_VALUE)
229 line = List_lines->value[line_idx];
230
231 G_debug(3, "line = %d", line);
232 if (!Vect_line_alive(Map, line))
233 continue;
234
235 ltype = Vect_read_line(Map, Points, Cats, line);
236
237 for (v = 0; v < Points->n_points; v++) {
238 G_debug(3, " vertex v = %d", v);
239 nvertices++;
240
To view the defects in Coverity Scan visit,
http://scan.coverity.com/projects/1038?tab=overview
