[GRASS-dev] new GRASS 6.4 modules
Hi all.
In the occasion of the release of GRASS 6.4, I think it would be good to revise the
current QGIS-GRASS modules. Specifically:
- there are modules that IMHO are of no use, and potentially confusing (e.g. several
of those who manage projections, etc.)
- there are new and useful modules to add to the toolbox
- not all modules have been thoroughly tested.
I encourage therefore GRASS users to help us defining both a wishlist for modules to
be included ad a deprecated list, and to let us know if there are non-functional
modules, so they can be fixed.
Thanks.
On Fri, Sep 10, 2010 at 10:09 AM, Paolo Cavallini <cavallini@faunalia.it> wrote:
Hi all.
Paolo - agreed, an important issue. Please suggest a
wiki page where we can collect responses.
Il 10/09/2010 20:02, MORREALE Jean Roc ha scritto:
Paolo, if it is not of a too high level, could it be possible to write a
wiki page explaining how to wrote and update the grass modules in qgis ?
I would like to help on this point but I don't know how.
Simple:
http://www.qgis.org/wiki/Adding_New_Tools_to_the_GRASS_Toolbox
See also:
http://www.qgis.org/wiki/Adding_New_Tools_to_the_GRASS_Toolbox#Modules_which_can_be_added
and following.
(and yes, Markus, this replies to your other suggestion too; see and below).
All the best.
Done (I think I annuonced it earlier):
see at the end of the page.
We definitely need help.
All the best.
to help I made a wiki table with all grass 6.4 modules:
http://grass.osgeo.org/wiki/GRASS-QGIS_relevant_module_list
note some dead qgis wiki urls at
http://grass.osgeo.org/wiki/Development#GRASS_and_QGIS
needs to be improved, you can sort by columns by clicking on the bowties
Hamish
Thanks a lot Hamish.
Anyone willing to carry on the work? For instance, I assume all d.* modules are not
relevant for QGIS, right?
If we can come out with a clean list, we'll do our best to implement the missing,
important modules.
All the best.
BTW: if we can have a well-thought list, before the upcoming hackfest[0], we'll do
our best to implement the suggestions.
BTW2: if any grass-dev or grass power user would like to join us at the hackfest,
they'll be most useful, and this can result in a greatly improved GRASS toolbox.
All the best.
[0] http://www.qgis.org/wiki/4._QGIS_Hackfest_in_Wroclaw_2010
W dniu 25.09.2010 18:33, Paolo Cavallini pisze:
In case I don't leave Wroclaw before the hackfest, I'll be there for a day or two to help.
Maciej Sieczka
http://www.sieczka.org
Hi Paulo:
Two questions about the table - Do you think it's necessary/desirable to have a separate column for each release of QGIS?
How about color coding the rows like the DebianGIS "thermometer". (If this idea is acceptable, I'm willing to do the wiki formatting.)
Micha
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
closer example, using {{templates}}, which may look slightly
familiar :slight_smile:
http://wiki.osgeo.org/wiki/Live_GIS_Disc_Testing#Package_testing_matrix
http://wiki.osgeo.org/wiki/Template:Pass
http://wiki.osgeo.org/wiki/Template:Issues
http://wiki.osgeo.org/wiki/Template:Fail
Hamish
Great idea.
So I would need to create a wiki {{template}} with, i.e.
Present
Should be added
Should be removed (is this category really necessary??)
Not relevant
Not possible
Micha
Hamish
This mail was received via Mail-SeCure System.
Micha Silver
http://www.surfaces.co.il/
Hi all.
I'm not authoritative here, but I believe we should target only current QGIS trunk.
There has not been any backporting until now, so any fix will go on trunk only.
Yes, I think a rating "crucial - important - minor" or similar would be very good to
help focusing our efforts.
Thanks a lot.
sounds good from where I'm sitting.
similar would be very good to help focusing our efforts.
ok, "Priority" column now added to the wikimedia table.
...oh, so the qgis wiki is really a themed Mediawiki? I make the table
in the GRASS wiki because I thought it wasn't. Feel free to move it over
to the qgis wiki-space if you think that's a more appropriate home for it.
hmmm, but then the module man-page templates links would stop working.
(shrug)
Hamish
