[GRASS-dev] new grass add-on
Hello,
I want submitt a new raster script in the grassaddons.
The raster command name is r.inund.fluv.
This command allows to obtain a fluvial potentially inundation map given a high-resolution DTM of the area surrounding the river and a water surface profile calculated through an 1-D hydrodinamic model.
For more inundation see the r.inund.fluv.html file into the r.inund.fluv folder.
Only one question... I've a osgeo_id and I've made the dowload and installed the TortoiseSVN program .
How can I put my folder into the https://svn.osgeo.org/grass/grass-addons/raster ?
Thanks in advanced!
Roberto
Hi Roberto,
On Tue, Apr 29, 2008 at 12:01 PM, roberto.marzocchi
<roberto.marzocchi@gmail.com> wrote:
Hello,
This is great!
folder.
The procedure to obtain write access to the GRASS Addons SVN
is explained here:
http://trac.osgeo.org/grass/wiki/HowToContribute
-> Procedure to request GRASS-SVN write access
    -> GRASS-Addons-SVN repository
Please take a look there and submit the needed info to me
or another developer.
I’ve a problem using the GRASS Addons subversion.
I made a checkout of grass-addons folder, then I add a new folder (grass-addons/raster/r.inund.fluv).
And then I’ve a problem when I try to commit the grass-addons folder. The message error is this:
"Error: Commit failed (details follow):
Error: MKACTIVITY of ‘/grass/!svn/act/3b53eff3-320e-324f-b2ae-62f27863c1e6’: 403 Forbidden (https://svn.osgeo.org)"
Anyone has an idea of error?
Thanks in advanced
Roberto
Markus Neteler ha scritto:
On 30/04/08 11:23, roberto.marzocchi wrote:
I've a problem using the GRASS Addons subversion.
And then I've a problem when I try to commit the grass-addons folder. The message error is this:
"/Error: Commit failed (details follow): Error: MKACTIVITY of '/grass/!svn/act/3b53eff3-320e-324f-b2ae-62f27863c1e6': 403 Forbidden (https://svn.osgeo.org)"/
Did you submit with your login and the entered your password ? See
http://trac.osgeo.org/grass/wiki/DownloadSource
-> Committing code to SVN (developers with write access)
Moritz
Thanks in advanced
Roberto
Hi Roberto,
Hello,
This is great!
folder.
is explained here:
grass-dev mailing list
grass-dev@lists.osgeo.org
Maybe my osgeo id isn't available for grass???
http://svn.osgeo.org/grass/grass-addons/contributors.csv
Thanks for your help!
R
Moritz
Thanks in advanced
Roberto
Hi Roberto,
Hello,
This is great!
folder.
is explained here:
On Wed, Apr 30, 2008 at 3:14 PM, roberto.marzocchi
I guess so. Did you communicate it to a developer?
This process will not be automated since we want to keep control
over write access to SVN.
The current list of members of Group: grass_addons
  annalisapg
  dylan
  ejtizado
  florian
  hobu
  maltehm
  maxi
  neteler
  tomce
  warmerdam
  ychemin
If the indicated Wiki pages aren't clear, please me me/us know.
Exactly, my userid (robertomarzocchi) isn’t in the current list of members.
Sorry, but I 've an other question…How can I communicate it to a developer?
With this mailing list?
Thank you very much!!!
Roberto
Reading the new version of http://trac.osgeo.org/grass/wiki/HowToContribute I understand this:
I must write to you (currently you’re the GRASS-PSC chair) and to other developers. Only the grass developers or the GRASS-PSC chair can add my “osgeo_id” to the OSGeo LDAP authentication system.
If I correctly understand, so is clear!!
An other suggest: You can write the e-mail address of grass developers list too. Before I’m not sure that I must write to the grass developers list for obtain the authentication of my “osgeo_id”.
Roberto
hi Roberto,
On Fri, May 2, 2008 at 9:58 AM, roberto.marzocchi
I must write to you (currently you're the GRASS-PSC chair) and to other
Since we talk about the GRASS-SVN-Addons: to me *or* to another developer.
"osgeo_id" to the OSGeo LDAP authentication system.
Right.
Yes. I have polished wording again:
http://trac.osgeo.org/grass/wiki/HowToContribute#ProceduretorequestGRASS-SVNwriteaccess
too.
I think it is better to get into personal contact with a developer. The
list is daily filled with messages, a request can easily get lost.
Before I'm not sure that I must write to the grass developers list for
obtain the authentication of my "osgeo_id".
Do you think that the again modified Wiki page is clear now?
BTW: 'robertomarzocchi' is now activated for GRASS-Addons-SVN.
Please submit your script following the standards described in
SUBMITTING_SCRIPTS
(thanks for your patience - it actually helps to get the Wiki page
clear also for other future contributors)
Happy hacking,
hi Roberto,
[http://trac.osgeo.org/grass/wiki/HowToContribute](http://trac.osgeo.org/grass/wiki/HowToContribute) I understand this:
Yes, sorry I wanted to say "or" but I wrote “and
Right.
[http://trac.osgeo.org/grass/wiki/HowToContribute#ProceduretorequestGRASS-SVNwriteaccess](http://trac.osgeo.org/grass/wiki/HowToContribute#ProceduretorequestGRASS-SVNwriteaccess)
too.
“you may contact an active developer, see grass-dev mailing list archive”
Very clear!
SUBMITTING_SCRIPTS
OK! I submit my script.
Do You made the update of the page http://grass.osgeo.org/wiki/GRASS_AddOns or I must made something too?
Do you’ve received my mail with a version of the script for the next releases of grass, three days ago?
There are some difference between the grass_addons directory! If You didn’t receive the mail, I may re-sent to you!
Thanks for your patience!!!
Happy hacking,
cheers
Roberto
On Fri, May 2, 2008 at 2:46 PM, roberto.marzocchi
Please do it. I have added a note about this to the trac page, too.
Do you've received my mail with a version of the script for the next
Yes, received, but...
There are some difference between the grass_addons directory! If You didn't
... I cannot check all submissions personally. If there are relevant
changes, please upload to SVN.
Best,
