Dear GRASS Users,
As some of you might already have noticed, there is a new GRASS GIS add-on available, called v.stream.order:
https://grass.osgeo.org/grass70/manuals/addons/v.stream.order.html
This module computes various types of stream order (Strahler, Shreve, Scheidegger Drwal) of stream network vector maps. Specifically, stream order is calculated for each sub-network as identified by their respective outlet vector points. At its current state, v.stream.order works on GRASS GIS 7.1svn.
The module v.stream.order includes a comprehensive manual and a testsuite and is available via from the GRASS add-on SVN repository
https://svn.osgeo.org/grass/grass-addons/grass7/vector/v.stream.order/
Maybe a future extension of v.stream.order will also allow to consider more complex networks that include e.g. loops and interconnections.
The module v.stream.order has been developed in the scope of the BiodiERsA project FISHCON (Project partner: IGB Berlin) and was programmed and implemented by Geoinformatikbüro Dassau GmbH, Soeren Gebbert.
I hope the tool is also of use for some of your future analysis.
Johannes
