----- Original Message Follows -----
To: Trevor Wiens <twiens@interbaun.com>
Cc: Developers List <grass-dev@grass.itc.it>,
grass@grass.itc.it
Subject: Re: [GRASS-dev] New installation for wxPython GUI
Date: Mon, 14 Aug 2006 09:04:06 +0100
[CC list snipped; anyone who is interested reads one of
these lists.]Trevor Wiens wrote:
> Sockets are fast and from what I understand are a good
> cross platform solution.Windows doesn't support Unix-domain sockets (Cygwin
emulates them using TCP sockets). You could either use TCP
sockets (although you would have to implement some form of
access control) or named pipes.> In this context however the issuing of
> d.* commands would pretty much disappear from CLI use.
> Instead users would do something like "g.ui map1 add
> rast foo", "g.ui map1 redraw", or "g.ui map1 tree" (to
> see the display tree in a simple text representation).In the "add" case, you may as well just specify the name
of the actual command which will be used to perform the
rendering (e.g. "d.rast") rather than creating a new
GUI-specific layer. IOW, every layer would be a "command"
layer.
I disagree. If we are thinking of rewriting some of these
commands
it makes more sense to me to remove them from use with as
simple a
command line interface as possible that will not need to be
changed
in the future. Thus whatever changes behind the scenes are
implemented
by developers and as little as possible of the user
developed scripts break.
Further, by making every layer a command layer, just means
more redundant
typing and making GRASS CLI use more difficult for newbies.
I don't want to
see GRASS dumbed down, but if I can make it easier to use
with no loss of
control or functionality, why not?
> This could be later expanded to support frames with
> multiple views, etc. This type of interface could be
> used to later generate final output as bits were written
> "g.ui map1 print ps foo.ps" or "g.ui map1 print png
foo.png"Once you have the ability to control the GUI through
external commands, it's trivial to provide
backward-compatibility by extending the raster library so
that running d.* commands from a shell would signal the
GUI to add a corresponding command layer.> I want to consider issues related to frames and the
> inserting of text of other graphics in this context as I
> deeply dislike having to fiddle with data in two places
> so would like to see a sufficiently advanced
cartographic system eventually constructed for GRASS that
> use of drawing programs to pretty things up will be a
thing of the past.I don't think that will ever be the case. There will
always be situations where you want to perform advanced
graphical processing of a kind that is best left to
general-purpose graphics software.
Undoubtedly there will always be exceptions that will
require some
tweaking but for use in production situations, which is my
interest
as I'm not an academic but a consultant, these need to be
exceptions
not the rule (as has been the case for most GIS systems open
or
proprietary).
T
Trevor Wiens
Trevor Wiens
