Michael Barton
School of Human Evolution &Social Change
Arizona State University
...Sent from my iPad
On Aug 24, 2015, at 7:43 AM, Anna Petrášová <kratochanna@gmail.com> wrote:
Hi Michael,
sorry to report but the new binaries (70 and 71) don't work, the gui
doesn't open with this error. I already saw this error multiple times and
it might be enough just to make distclean and recompile or fresh svn
checkout.
GRASS 7.1.svn (loc_ncarolina_spm_base0.3.1):~ > Traceback (most recent
call last):
File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py",
line 140, in <module>
sys.exit(main())
line 132, in main
app = GMApp(workspaceFile)
line 46, in __init__
wx.App.__init__(self, False)
File
"/Applications/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core.py", line
7981, in __init__
self._BootstrapApp()
File
7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
line 79, in OnInit
from lmgr.frame import GMFrame
File
"/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
line 50, in <module>
from lmgr.layertree import LayerTree, LMIcons
File
"/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/layertree.py",
line 37, in <module>
from mapdisp.frame import MapFrame
File
"/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/mapdisp/frame.py",
line 34, in <module>
from vdigit.toolbars import VDigitToolbar
File
"/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/vdigit/toolbars.py",
line 30, in <module>
from iclass.digit import IClassVDigit
File
"/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/iclass/digit.py",
line 23, in <module>
from vdigit.wxdisplay import DisplayDriver, TYPE_AREA
ImportError: cannot import name TYPE_AREA
Also, v.in.lidar or las2las (anything using liblas) doesn't work. I don't
have GDAL 1.10, but 1.11.
dyld: Library not loaded:
/Library/Frameworks/GDAL.framework/Versions/1.10/GDAL
Referenced from:
/Applications/GRASS-7.1.app/Contents/MacOS/lib/liblas.2.2.0.dylib
Reason: image not found
Trace/BPT trap: 5
If you don't have time to look at it now, could you please post the GRASS
7.0.0 binary which I believe worked.
Thank you,
Anna
On Wed, Aug 12, 2015 at 6:29 PM, Michael Barton <Michael.Barton@asu.edu>
wrote:
I just uploaded new binaries for:
GRASS 6.4.6 stable
GRASS 7.0.1 stable
GRASS 7.1 development
These all run on current versions of Mac OS X 10.9 through 10.10.4
Note that I’m using a newish version of GDAL complete (1.11 dated May
2015)
I’ve heard that there may be problems compiling GRASS on OS X 10.11. I
don’t know if these binaries will run under the new OS or not. However,
this new OS version is not yet released. So problems may be worked out by
the time it is finalized.
For now, enjoy GRASS.
Michael
____________________
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
grass-dev mailing list
grass-dev@lists.osgeo.org
