[GRASS-dev] new option to set options to be required or exclusive, etc
I have three flags: i, d and c. When I use
#%rules
#%required i,d,c
#%end
and then run the script, I get the message:
Unknown option “i” in rule
Unknown option “d” in rule
Unknown option “c” in rule
ERROR: Internal error: option or flag not found
Any idea what I might be doing wrong? Using the same for options seems to work. So does this not work for flags?
On Fri, Jan 16, 2015 at 12:16 PM, Paulo van Breugel
#%rules
#%required i,d,c
              ^^^^^^^ -- I think the colon is missing
#%end
Unknown option "i" in rule
Unknown option "d" in rule
Unknown option "c" in rule
The manual page of g.parser describes this (the online manual will
show it in 20min from now:
http://grass.osgeo.org/grass70/manuals/g.parser.html#conditional-parameters
> #%rules
> #%required i,d,c
> #%end
Ah, yes, I did use the colon.. this was a copy/paste from an trial to see
if I could get it to work without colon. Both do not work for me/
I see what I missed: the flag needs to be given with a leading "*-*":
#%rules
# %required: -i,-d,-c
#%end
It might be useful to have an example of both rules for options and for
flags (in the example section or perhaps even in the 'Conditional
parameter' section like below
For scripts, relationships are specified using a "rules" section, e.g.for
options:
  #%rules
  #%required: altitude,elevation
  #%end
and e.g., for flags:
        #%rules
  #%required: -f,-i
        #%end
p.s. note that in the help file the colon is still missing in the example
in the Conditional parameter section.
On Fri, Jan 16, 2015 at 1:16 PM, Paulo van Breugel
I see what I missed: the flag needs to be given with a leading "-":
#%rules
#%end
flags (in the example section or perhaps even in the 'Conditional parameter'
section like below
options:
#%rules
#%end
#%rules
#%required: -f,-i
#%end
I have added that. The example will show up online in ~ 24hs.
p.s. note that in the help file the colon is still missing in the example in
It was already fixed... as mentioned the online manual needed some
minutes to be updated.
options:
  #%rules
  #%end
        #%rules
  #%required: -f,-i
        #%end
It should probably have an example using both options and flags; they
can be mixed within a rule.
