[GRASS-dev] new pan sharpening script added to grass7 addons
I just uploaded a new script that–i.pansharpen–allows the user to select from several different algorithms to do pan sharpening of multispectral imagery. By default, it will run on multiple cores (you can select serial processing with the -s flag). I’m considering the script ultimately as an enhancement of and replacement for the i.fusion.brovey script (which uses only the Brovey pan sharpening algorithm) in trunk. So testing would be very welcome. There is a pretty comprehensive help file that accompanies it.
Michael
C. Michael Barton
Visiting Scientist, Integrated Science Program
National Center for Atmospheric Research &
University Corporation for Atmospheric Research
303-497-2889 (voice)
Arizona State University
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Tue, Jul 3, 2012 at 7:30 PM, Michael Barton <michael.barton@asu.edu> wrote:
I just uploaded a new script that--i.pansharpen--allows the user to select
processing with the -s flag). I'm considering the script ultimately as an
Very nice, Michael!
I made a quick test with Brovey (and added a related example to the docs),
works well.
If users could test please with other data... i.fusion.brovey should
be replaced then.
Thanks for testing and for the additional examples Markus.
Michael
Very nice, Michael!
works well.
be replaced then.
_____________________
C. Michael Barton
+1 to add it to trunk, much needed addition for RS guys
________________________________________
From: grass-dev-bounces@lists.osgeo.org [grass-dev-bounces@lists.osgeo.org] on behalf of Michael Barton [michael.barton@asu.edu]
Sent: Wednesday, July 04, 2012 4:37 AM
To: Markus Neteler
Cc: grass-user; GRASS developers list
Subject: Re: [GRASS-dev] new pan sharpening script added to grass7 addons
Michael
Very nice, Michael!
works well.
be replaced then.
C. Michael Barton
grass-dev mailing list
grass-dev@lists.osgeo.org
