[GRASS-dev] New section in GRASS wiki for installation under Mac using homebrew
Hi
I just added a section / new page in the WIKI for installation of GRASS
using homebrew. Please see
http://grasswiki.osgeo.org/wiki/Compile_and_Install#Mac_OSX
and
http://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew
It would be great if some Mac / homebrew users would see if it works and
give me comments here.
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
On Thu, Jul 30, 2015 at 6:38 AM, Rainer M Krug <Rainer@krugs.de> wrote:
Hi
and
I will try to test it next week. Thank you for your efforts!
Anna
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
grass-dev mailing list
grass-dev@lists.osgeo.org
Anna Petrášová <kratochanna@gmail.com> writes:
Hi
and
Great - let me know how it goes, although I don't know if I will be able
to reply as I am away and possibly only have very limited internet
access.
Rainer
Anna
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Very interesting!
From the brew recipe, it looks that one needs all dependencies installed via homebrew, is that right? I’m thinking that most will have Kyngsburie’s Frameworks already installed (at least GDAL). Same goes for wx-python.
best
Carlos
Hi
and
Great - let me know how it goes, although I don’t know if I will be able
access.
Rainer
Anna
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
  • Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
Can’t stop the signal.
Hi
The homebrew formula doesn’t really work on OSX 10.11 beta. In the log file (link below) I can see the same errors in compilation I got when tried to compile svn. They are related to html manual pages, but prevent installation from continue.
Carlos
log files:
https://www.dropbox.com/s/ufvw198bix7t7xj/02.make?dl=0
https://www.dropbox.com/s/1ij9c5havtjczk1/config.log?dl=0
brew tap rkrug/head-only
==> Tapping rkrug/head-only
Cloning into ‘/usr/local/Library/Taps/rkrug/homebrew-head-only’…
remote: Counting objects: 4, done.
remote: Compressing objects: 100% (4/4), done.
remote: Total 4 (delta 0), reused 4 (delta 0), pack-reused 0
Unpacking objects: 100% (4/4), done.
Checking connectivity… done.
Tapped 1 formula (27 files, 116K)
brew install grass-71
Error: rkrug/head-only/grass-71 is a head-only formula
Install with brew install --HEAD rkrug/head-only/grass-71
Warning: You are using OS X 10.11.
We do not provide support for this pre-release version.
You may encounter build failures or other breakage.
==> Installing grass-71 from rkrug/homebrew-head-only
Error: No available formula for nc_spm_08_grass7 (dependency of rkrug/head-only/grass-71)
guano$ brew install --HEAD rkrug/head-only/grass-71 --without-nc_spm_08_grass7
==> Cloning https://svn.osgeo.org/grass/grass/trunk
Updating /Library/Caches/Homebrew/grass-71–svn-HEAD
==> Patching
patching file include/Make/Install.make
Hunk #1 succeeded at 116 (offset 2 lines).
==> ./configure --prefix=/usr/local/Cellar/grass-71/HEAD --enable-shared --with-
==> make GDAL_DYNAMIC=
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
On Fri, Jul 31, 2015 at 11:54 AM, Carlos Grohmann <carlos.grohmann@gmail.com> wrote:
Very interesting!
best
Carlos
Hi
and
access.
Rainer
Anna
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
South Africa
Skype: RMkrug
PGP: 0x0F52F982
