[GRASS-dev] New: v.db.droprow
to be able to easily filter vector maps geometrically (i.e. remove
vectors) I have
written the v.db.droprow script (G6.5; needs a Python port for GRASS 7).
It removes vector objects (point, line, area, face etc.) from a vector
map through
attribute selection in the table.
Example: remove all vector with a certain attribute missing (nice when doing
random sampling).
cheers
On 11/08/09 14:49, Markus Neteler wrote:
vectors) I have
map through
random sampling).
Can't you do that with v.extract ?
Moritz
On Tue, Aug 11, 2009 at 5:53 PM, Moritz
doing random sampling).
It is using v.extract. But IMHO most non-power users won't get the idea to
use a reverse extraction to remove vectors via attribute selection...
Shouldn't this then be better documented ?
Just wondering whether multiplying the number of small scripts is really the best way to go...
Moritz
On Tue, Aug 11, 2009 at 8:10 PM, Moritz
Please suggest where... (if I/user don't know that I have to use
v.extract for this
in the first place since I want to *delete*, it needs to be documented
elsewhere).
best way to go...
Well, since we have
r.mfilter + r.mfilter.fp or
r.colors + r.colors.stddev
r.grow + r.grow.distance
r.rescale + r.rescale.eq
r.surf.idw + r.surf.idw2
r.what + r.what.color
Luckily the v.* family looks better...
With vector objects removal I don't see the problem (while I agree in general).
2009/8/11 Markus Neteler <neteler@osgeo.org>:
vectors) I have
Done in r38716.
map through
Also not sure if we need this script. In any case the name is probably
misleading. Prefix 'v.db' indicates that the module modifies only
attribute data, not geometry(?)
I have some questions regarding Bash script:
* are these extra checks needed (it's done by v.extract) [1,2]
* unused variables [3]
* G_OPT_OUTPUT instead of G_OPT_INPUT? [4]
Thanks, Martin
[1] http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/scripts/v.db.droprow/v.db.droprow#L86
[2] http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/scripts/v.db.droprow/v.db.droprow#L92
[3] http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/scripts/v.db.droprow/v.db.droprow#L97
[4] http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/scripts/v.db.droprow/v.db.droprow#L116
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
On Fri, Aug 14, 2009 at 10:15 AM, Martin Landa<landa.martin@gmail.com> wrote:
map through attribute selection in the table.
How would you do vector removal based on attributes?
Perhaps yes (I considered it a v.db.* since it uses the attribute table).
Yes, I think so: if you create a map with v.random it won't have
a connected table, so better don't badly crash. Likewise with
a non-existing map. I used existing msg strings (for translation).
Removed.
Right, fixed.
Thanks, Martin
thanks
2009/8/14 Markus Neteler <neteler@osgeo.org>:
Badly crash? After r38718:
$ v.db.droprow in=x out=x1 w='x' --o
ERROR: Vector map <x> not found
$ v.db.droprow in=p out=x1 w='x' --o
ERROR: Database connection not defined for layer 1
It seems reasonable to me.
Martin
2009/8/14 Martin Landa <landa.martin@gmail.com>:
BTW, why are you requesting the input vector map from the current mapset?
Martin
On Fri, Aug 14, 2009 at 12:16 PM, Martin Landa<landa.martin@gmail.com> wrote:
Fixed.
v.extract -r ... where=
Moritz
On Fri, Aug 14, 2009 at 3:30 PM, Moritz
Ok, while I disagree that this is obvious (especially to newcomers),
I'll remove the module now in 6.5.
