As there don't appear to be any show-stopping bugs in the new v.digit,
I've committed it to CVS.
Anyone with a pressing need for the XDRIVER-based version can get it
by updating the vector/v.digit directory with the tag
pre_vdigit_changes_2007023, e.g.
cd vector/v.digit
cvs update -r pre_vdigit_changes_2007023
Glynn,
you made an IMPRESSIVE work! Congratulations.
PS: the preset colors in the "Settings" tab are all black
currently (symbology) - maybe an initialization problem?
PPS: A wish: having "close" buttons in all "Settings" tabs would
be great
A question:
What's the idea of the "-n" flag? I could not find out the last
years Can we disable it (in the common "deprecated" way)?
Yep; fixed in CVS.
[symb_init_gui() has to come after symb_init(). I had to change the
initialisation because it was originally drawing the map before Tcl/Tk
was initialised; that won't work if you're trying to draw the map on a
Tk canvas.]
be great
To create a new map. Are you asking why it doesn't just do this
automatically if the map already exists? Possibly so that you don't
accidentally create a new map if you make a mistake entering the name
of an existing map.
Ignoring it would be trivial; just remove the "if ( new_f->answer ) {"
from around the code which creates a new map.
Yep; fixed in CVS.
Hmm, using CVS checked out just a moment ago I still have this issue.
Maciek
Tk canvas.]
be great
Just press the window close button (sorry if I didn't understand)?
> be great
Close buttons in *tabs*? For what purpose?
Right, I meant a close button for the entire window
or something reasonable.
Take for example the "Background" tab:
- click "Add command"
- write "Winnie The Pooh"
- then? Kill the entire settings window - not really obvious
("Winnie The Pooh" is then silently ignored/disappears)
I would expect some "confirm" thing or so or a "Done"
button below all tabs.
> > be great
Ah, an "Ok" button (apply changes and close window).
Add it to the RT as a wish; for now, I would rather stick to fixing
anything which broke as a result of switching from libraster to Tk.
AFAICT, we still need the -n for situations where v.digit is run with the
name of a map that does not yet exist. Using the -n flag will create a new
vector map with the specified name and let you start digitizing this map.
Michael
Glynn,
be great
A question:
Arizona State University
> A question:
The code in question is:
/* Open map */
mapset = G_find_vector2 (map_opt->answer, G_mapset());
if ( mapset == NULL ) {
G_message(_("New empty map created."));
Vect_open_new (&Map, map_opt->answer, 0 );
Vect_build ( &Map, NULL );
Vect_close (&Map);
Vect_open_update (&Map, map_opt->answer, G_mapset());
} else {
G_message(_("Map does not exist. Add flag -n to create a new map."));
exit(EXIT_FAILURE);
} else {
Vect_set_open_level(2);
Vect_open_update (&Map, map_opt->answer, mapset);
The -n flag is only checked if the map doesn't already exist. In that
case, it could just skip the -n check and create the map
automatically.
The only issue is whether there is a reason not to.
To go along with your impressive update of v.digit, I was able to now
re-institute automatic background display of any active layers in the GIS
Manager. This was functional in the x11 based d.m, but hasn't been
functional in the new display architecture. Now that it's all in a TclTk
canvas, I was able to get this running again.
I'm currently using the -n switch. If you get rid of it, I can take it out
of the v.digit command (and shorten the code a bit) in vector.tcl.
Michael
On 2/24/07 2:59 PM, "Glynn Clements" <glynn@gclements.plus.com> wrote:
Michael Barton wrote:
A question:
/* Open map */
Vect_close (&Map);
} else {
exit(EXIT_FAILURE);
} else {
automatically.
Do you mind if I change the display and digitizing controls window titles to
"Digitizing $map_name@$map_mapset" (from "v.digit - $map_name@$map_mapset".
This is a bit more descriptive, especially when run from the GIS Manager
rather than from the command line.
"Digitizing controls for $map_name@$map_mapset" might be even better for the
toolbox window, but I'm afraid that title would be too long for some maps.
Michael
A question:
/* Open map */
Vect_close (&Map);
} else {
exit(EXIT_FAILURE);
} else {
automatically.
be great
I can't see any good reason for "hiding" from the user the fact that they're using v.digit - can only imagine it making it harder for them to find hints and information and make bug reports more obscure?
Well what I took from previous discussions was its OK to use the -n flag even if the map already exists, because it is only checked if the map doesn't already exist! So it would be fine to just use it all the time, but probably a more preferable solution is just to get rid of it as it seems to be anomaly with no real use.
titles to
Good point. I second that.
out
of the v.digit command (and shorten the code a bit) in vector.tcl..
I don't have a strong opinion about it. However, eventual removal of
the -n flag should be postponed to GRASS 7 I think.
I just compiled and tested this in Windows: I can now digitize in windows
and display the resulting map. The only problem remains the db access
which still doesn't work, but this is more general than v.digit
Hello Michael
I just tested this and as far as I can see it doesn't work correctly. You stil have to press enter in the box after changing the line width for it to be picked up. And the default line width still isn't placed in the box to start with. Also if there is an OK button there should be a cancel too I think.
Paul
Michael
be great
