Von: Markus Metz
Gesendet: 14.08.2010 17:19:24
An: Helmut Kudrnovsky hellik@web.de>
Betreff: Re: [GRASS-dev] Nightly WinGrass-builds (65,70) broken
Helmut Kudrnovsky wrote:
Hi Martin,
Von: Martin Landa Gesendet:
14.08.2010 13:27:17
2010/8/14 Helmut Kudrnovsky
the nightly Wingrass65- and WinGrass70-builds seems to be broken:
[http://josef.fsv.cvut.cz/wingrass/grass65/\] => no files
[http://josef.fsv.cvut.cz/wingrass/grass70/\] => last build from 10-Aug-2010 16:01
yes, the problem are ctypes. Probably it would be better to disable it
on Windows.
>as you can see in my other mail about WinGrass70 compiling error
>([http://lists.osgeo.org/pipermail/grass-dev/2010-August/051577.html\]),
>there seems to be an additional cause for failing wingrass7.
>I've tried compiling wingrass65, there is only the ctypes problem.
>I've tried to start wingrass out of C:\OSGeo4W\usr\src\grass6_devel\bin.i686-pc-mingw32,
>there is following error:
>GRASS 6.5> Traceback (most recent call last):File "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/wxgui.py", line 65, in import >gui_modules.layertree as layertreeFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/layertree.py", line 40, in import >toolbarsFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/toolbars.py", line 42, in from nviz import >haveNvizFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/nviz.py", line 29, in import >nviz_mapdispFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/nviz_mapdisp.py", line 39, in from workspace import Nviz >as NvizDefaultFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/workspace.py", line 40, in import >wxnvizFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/wxnviz.py", line 59, in errtype = CFUNCTYPE(UNCHECKED(c_int), >String, c_int)NameError: name 'UNCHECKED' is not defined
same on linux
why is wxnviz loaded on startup?
Markus M
and after solving compiling wingrass7, it's the same here, when I want to start the wxgui:
GRASS 7.0.svn> Traceback (most recent call last): File "C:\Program Files\GRASS-70-SVN\etc\gui\wxpython\wxgui.py", line 65, in import gui_modules.layertree as layertreeFile "c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/gui/wxpython/gui_modules/layertree.py", line 40, in File "c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/gui/wxpython/gui_modules/toolbars.py", line 42, in File "C:\Program Files\GRASS-70-SVN\etc\gui\wxpython\gui_modules\nviz.py", line 29, in import nviz_mapdispFile "C:\Program Files\GRASS-70-SVN\etc\gui\wxpython\gui_modules\nviz_mapdisp.py", line 40, in from workspace import Nviz as NvizDefaultFile "C:\Program Files\GRASS-70-SVN\etc\gui\wxpython\gui_modules\workspace.py", line 40, in import wxnvizFile "C:\Program Files\GRASS-70-SVN\etc\gui\wxpython\gui_modules\wxnviz.py", line 59, in errtype = CFUNCTYPE(UNCHECKED(c_int), String, c_int)NameError: name 'UNCHECKED' is not defined
best regards
Helmut
___________________________________________________________
WEB.DE DSL SOMMER-SPECIAL: Surf & Phone Flat 16.000 für
nur 19,99 ¿/mtl.!* http://web.de/DSL-Doppel-Flatrate/
