There seems to be a problem again with the addons metadata on the server. Updating an addon works, but with the following warning:
Updating addons metadata file…
WARNING: Unable to parse ‘http://grass.osgeo.org/addons/grass7/modules.xml’: no element found: line 105, column 0
WARNING: No addons metadata available. Addons metadata file not updated.
The g.extension GUI does not fetch the list with addons, which I guess depends on the same xml file?
Paulo
